Old 01-30-2006, 04:54 PM
carolina pyro carolina pyro is offline
axle ratios
hi iv got a 01 z71 with a 5.3 in it dont know what rear axle ratio i have how do i find this out?! tried every book i can find.
Old 01-30-2006, 05:32 PM
Rammer500 Rammer500 is offline
Re: axle ratios
Look on the RPO sticker on your glove box door for these codes.
GT4 Rear axle, 3.73 ratio
GT5 Rear axle, 4.10 ratio
GU6 Rear axle, 3.42 ratio
Old 01-31-2006, 08:24 AM
Re: axle ratios
thanks. what do i need to do to find a 4.10 gear for that rear end?
Old 01-31-2006, 12:44 PM
twomorestrokes's Avatar
twomorestrokes twomorestrokes is offline
Re: axle ratios
You do realize that you'll need to swap to 4.10's in the front diff as well, right? As for where you'd look for gear sets, you can get them about anywhere that specializes in truck parts. Probably spend about 500 a set at the dealer plus labor. If a shop sells you the parts and does the labor for you, the bill will be a stiff one. You cannot recallibrate your speedo through the computer either, like you can on the newer trucks. Expect a bill for that as well.
'02 2500HD 6.0/4.10 Air Lift bags, 175 psi onboard air
Old 01-31-2006, 04:03 PM
spudglo08 spudglo08 is offline
Send a message via AIM to spudglo08
Re: axle ratios
There is a 75% chance that you have 3.73's in your Z
Old 02-01-2006, 07:16 AM
Re: axle ratios
...and 68% of all facts are made up on the spot.
