Old 01-30-2006, 04:40 PM
directory's Avatar
directory directory is offline
just wondering
does the f1 come in an automatic?
the reason i was wondering was, i know the drivers seat is in the middle, so linkage options would be limitied, i guess.
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 01-30-2006, 04:47 PM
payso's Avatar
payso payso is offline
Re: just wondering
Im 100% they are all manual!!!
Old 01-30-2006, 04:55 PM
directory's Avatar
Re: just wondering
ok, cool.
i didn't know either way. it was jsut something i had thought of. thanks
SKYWARN
we be clubbin'
--B
Old 01-30-2006, 05:03 PM
Peloton25's Avatar
McLaren Fanatic
Re: just wondering
The F1 uses a bowden cable linkage.
What are bowden cables you ask?
Invented by Frank Bowden, a bowden cable is a type of flexible cable used to transmit mechanical force or energy by the movement of an inner cable (most commonly of steel) relative to a hollow outer cable, generally a spiral steel wire with a plastic outer sheath.
The linear movement of the inner cable is generally used to transmit a pulling force, although for very light applications over shorter distances a push may also be used.
There was only one transmission for the F1 road cars and they were all manual with no paddle actuation available. Later the longtail GTRs used a sequential manual setup developed by Xtrac that appears to use a mechanical rod linkage.
>8^)
ER
