has sport shift, goes into 2nd all by itself, wont upshift or downshift until light goes out. Any help would be appericated.
Re: 1991 Accord DX tranny problems
until what light goes out?
Check out the FAQ, and try doing the part where you pull the codes from teh ECU yourself. I bet you will find something there.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
i think he means when you use the sport shift option...
when selected a light turns on in the dash to display that sport is enabled .. problems occur when it is enabled |
new to forums
i have a question, what can be the problem when my car will not take off in drive. i have to step on the gas and it will move but the engine is straining. once i get it going it is fine but its just the first gear that will not work. is their a quick fix or should i get a new tranny? |
have you tried manually shifting into 1st gear and see if that changes anything ?
actualy that is the only way the engine does not strain. i have to but it in 1st or 2nd to get enough speed then i shift up.
no engine light on ?
engine light comes on after about 20 min of driving.
or do you know how to check the engine code ? that may give some good info too.. |
i had a mechanic check and pull the codes for it but the only thing that came up was the speed censor. i can tell that the censor is bad because i will be driving and the speedometer will not read it stays at 0 mph
how long ago was that ? i suggest have it done again for free at autozone or yourself.. its pretty easy on them cars...
post up the exact codes you get .. |
will do
thanks alot |
and what is stopping you from pulling the speed sensor and replacing it ?
well i dont know exactly what the censor looks like and where i can buy it and not cost me a arm and a leg. i have heard they are expensive for a censor. do you by any chance know where i can get my hands on one?
yes new they do cost approx 120.00 but im sure you can pullone from the auto pick and pull yard...
invest in a service manual .. $15.00 the part is not ver big at all... small enough to fit in your pocket (if you know what i mean) |
