Old 06-19-2002, 01:46 PM
MKS MKS is offline
D16a9
Does anyone have and info or specs in the D16A9 engine ...
there is one gonig on ebay UK for £150 jsut wanted to know if its worth me replacing my 1.4 Twin Carb with that.... I would have to find all the wirnig myself so i guess it would be quite hard to do anyway ...
So if ya have any info plz say
1989 Toyota Supra 3.0i Turbo
150mph I think I'm nuts
Custom S/S Exhaust 5" Tailpipe
K&N Induction kit
Bailys Piston Dump Valve (WOOSH)
Wategate Shimmed by 5mm ummm boost
Old 06-19-2002, 01:50 PM
MKS MKS is offline
or do Civics come stock with this engine ... ?? i may just by another civic that is being scrapped or somthing and strip it down..
K&N Induction kit
Old 06-19-2002, 02:51 PM
MKS MKS is offline
Anyone have any info on this ??
K&N Induction kit
Old 06-19-2002, 04:03 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
hey mks, is the the sohc zc i hear about ? if so my friend may want to buy the dual carbs, if you swap your motor
Old 06-19-2002, 04:05 PM
CRX586's Avatar
CRX586 CRX586 is offline
Found this on the web, I think its a ZC euro engine?
D16A8/A9 1595cc
4 cyl, 16 valve
DOHC
9.6:1 c.r.
PGM-FI (MPFI)
137 bhp @ 6800
Redline: 7200 rpm 108 lb-ft @ 5700
88-91 Si16-1.6i
88-91 CRX Si16-1.6i
(Asian specs)
90-93 Integra LS
90-93 Integra RS
D16A8 Euro. spec featuring EFI
D16A9 Euro. spec featuring Carbs
http://tech.hybridgarage.com/tech/specs.htm
http://hybrid2.honda-perf.org/tech/zcinfo.html
Looks like a decent upgrade from your engine...
Old 06-19-2002, 05:21 PM
MKS MKS is offline
Humm cool ... I dont suppose anyone would know but if I did get this engine could I just do away with the injection system and strap my carbs on... I guess if I could i would not have to mess around with the wiring too much ....
Or would the carbs from the 1.4 be too small ??
K&N Induction kit
Old 06-19-2002, 05:35 PM
MKS MKS is offline
Scrap what i just said hehe ...
Looks like the A9 is carbed engine heeh I just did not read CRX586s post right hehe ...
So anyone know if a GL is anything similar to a DX or SIs wiring harness ????
K&N Induction kit
Old 06-19-2002, 06:36 PM
CRX586's Avatar
Actually, maybe you're right. Don't quote me, I'm just forwarding some information I found.
This site says that the d16a9 is mpfi, not dual carb.
http://www.carpage.tmfweb.nl/specs.htm
Can you use your exising dual carbs instead? I'm not sure, someone here should know...
You have the d14a1 engine (1.4L SOHC 2 carburetors), right?
Old 06-19-2002, 07:45 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
The old 1.4L carbs will be WAY to small for a ZC. (Which is what the engine your talking about sounds like).
However there were Carb'd versions of the ZC sold in Japan, and there are webber style manifolds avliable.
The best option would be to convert your car to Fuel injection, or even sell your car and buy and injected model and swap the ZC into that.
However it would be easier (since there is simply less work) to get hold of either a carb set up from Japan or find a webber manifold in the US or Europe, and fit it with either wbbers or dellortos or similar. (just dont use Strombergs or SU's!! <- joke about british cars).
Old 06-20-2002, 12:21 PM
MKS MKS is offline
Thanks for the info guys hehe
Just gotta decide what to do hehe ............
Hay anyone know any good sites in the UK that sell honda engines ??? or any good honda parts
K&N Induction kit
where to get tunin' bitz for D16A9 Civic Jim '88 - '91 Civic | CRX | Wagon | Shuttlee 3 01-17-2003 11:28 AM
D16a6 swap D16a9 Civic DOHC '88 - '91 Civic | CRX | Wagon | Shuttlee 10 10-04-2002 01:04 PM
d16a6 swap d16a9 Civic DOHC Europe 2 09-28-2002 01:31 PM
Swap D16a9 engine for b16a2 krzychuk Europe 13 07-16-2002 06:55 AM
Changes between D16A9 and B16A1/2 krzychuk '88 - '91 Civic | CRX | Wagon | Shuttlee 7 07-12-2002 04:03 PM
