Old 01-30-2006, 02:10 PM
livin_tha_lyfe33 livin_tha_lyfe33 is offline
97' grand caravan horn trouble
I attend school a Tech HS in the automotive area and as a project decided to bring my mothers 1997 Dodge Grand Caravan 3.3 Liter in. I was going to work on the horn but can't find any diagrams and even my instructor is unsure about where it would/could be located in the compressed front end. So...if anyone could help me in any way it would be greatly apprectiated.
Old 01-31-2006, 08:19 PM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Re: 97' grand caravan horn trouble
Here's a basic wiring diagram from online. I would think it unlikely that both horns are bad so I would look for a ground problem, blown fuse or a bad relay.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 02-01-2006, 03:42 PM
AlainB's Avatar
AlainB AlainB is offline
Hi,
You may also suspect the clockspring. It was the problem on my 96 caravan. If your air bag light stay on, then that's it! Almost sure!
If I remember well, the horns are on the driver side. You should see them if you remove the round cover in front of the wheel.
Alain
2001 Dodge Caravan SE, 3,3 - 4 speed
Old 02-01-2006, 05:31 PM
wafrederick wafrederick is offline
Banned
The clockspring is bad,the horn is part of the clockspring.Disconnect the battery before doing this.You do not want the airbag blowing if you do something wrong.
Old 02-01-2006, 10:54 PM
Soccer dad Soccer dad is offline
Originally Posted by AlainB
Hi,
Alain
Clock spring for me too! airbag light was on all the time,horns had to be replaced regardless as they were burned out,Dealer covered the clock spring with 160.000Kms its an outstanding warranty issue.Check with them first, they will need your V.I.N.
My 96 has the horns mounted on the front left as AlainB mentions, I never thought of the access hole in front of the wheel? anyway just ahead of the wheel (look way up under the fender) the wires are easily removed and probed with a test light.
Old 02-03-2006, 11:12 PM
moparman58 moparman58 is offline
The horns are under the headlight on the driver's side. Try pulling the headlight unit for easier access as well as through the access hole in the front wheel well. Best access is by pulling the bumper cover. If it is the clockspring, there was a recall for '97s, so you might want to check to see if that was replaced on your mom's van first. The dealer should fix it if it wasn't replaced.
Old 02-08-2006, 08:08 AM
HeadlessHorseman's Avatar
HeadlessHorseman HeadlessHorseman is offline
Send a message via AIM to HeadlessHorseman
Before you get started, you should run your VIN through Dodge's Recall Check Procedure. The results of this check may (or may not) have some bearing on your current problem and your Dealer may have to fix it FREE by law. To find out if your vehicle has any current unperformed or incomplete recalls or customer satisfaction notifications, get the last 8 characters of your VIN and go here to make sure that your vehicle has had ALL of its recall work done:
http://www-5.dodge.com/webselfservic...m%28%27R%27%29
Old 06-07-2006, 12:13 AM
timd timd is offline
My horn quit and the fuse and relay are OK. I haven't checked the horns yet that's next. I checked the Dodge Safety Recall and the way it reads is that the air bag light has to be constantly on before they'll change out the clocksping for free. I don't think they'll change it just for an inoperative horn...even tho the horn is a safety item also. Try getting a car to pass inspection w/o a horn!!
Old 06-26-2006, 09:59 PM
Update: Shortly after my last post about the horn not working, the cruise control stopped working...then shortly after that, the AirBag light came on and stayed on. Now I can get it all fixed for FREE.
