New to the forum, I have 98 chevy blazer, which is making a whinning sound comming from the left front. Only when I am moving, no sound when stopped, with some vibration when moving. When I turn steering wheel to left, it quits. I am thinking wheel bearing, but would appreciate other thoughts on this. If it is wheel bearing, what is involved in replacing it.
Re: wheel bearings
There is a possiblity its the bearing, but in most cases its your brake pads. When was the last time you had a brake job done?
Re: wheel bearings
I put new pads on about a month ago, you could be right on that. Maybe I should check to make sure everything is at it should be.
Re: wheel bearings
i've have the same problem, except its the right front and when i turn right it stops making the noise. I have already replace the front left hub(includes bearing) so i assume that my front right is bad too.
Re: wheel bearings
More then likely its the bearing. The job is not all the difficult, however the bearing is a sealed unit and comes with the a abs sensor built in. Just remember when you turn left the weight transfers to the right taking the load off of the left bearing which is why it gets quiet. When installing the new one be sure to follow the torque specs when putting the hub nut back on. If its not torqed correctly you'll burn the bearing up in a few weeks. Good luck
1999 BLAZER ZR2 KENWOOD HEADUNIT KDC-415S KENWOOD PS-150 AMP JL AUDIO 10W6 BOSE SPEAKERS 6X9, 4X6 PARNELLI JONES DIRT GRIP 31 X 10.5 X 15 K&N FIPK COLD AIR INTAKE APC CARBON FIBER TAIL LIGHTS
Re: wheel bearings
Thanks for info, I will work on bearing this wknd.
Re: wheel bearings
Jack the front end up and spin the wheel - you will feel a bad hub grating.
If a 4wd jack up under the lower control arm so the CV joint will still turn - could be that too. 3 bolts hold the 1 piece hub on and if 4wd you need the 36mm cv shaft hub nut socket too. |
