Old 01-30-2006, 10:06 AM
dh302 dh302 is offline
Question 1986 Chevy 1 ton 4x4 Front End Shaking
My son has a 1986 Chevrolet 1 tone 4x4 pickup with hydra boost brakes. When you apply the brakes at 40 mph or more the truck's front end will start shaking violently. Even after you let off the brakes the truck will continue to shake until the truck slows down. It's not just a slight shaking, it shakes so hard it throws things off the dash, seat, etc. It even broke the exhasut pipe hanger! The ball joints, tie rod ends, etc. seem to be tight. I’ve hade the tires rebalanced. A couple of weeks ago my son changed out the power steering pump (which also runs the hydra boost brakes) because the pump was leaking. I don’t know if that has anything to do with it or not. It has larger than factory size tires and wheels. Next I was going to take the shimmy shock off and check it. Does anyone have any suggestions? Thanks.
Doug
Old 01-30-2006, 04:53 PM
jveik jveik is offline
Re: 1986 Chevy 1 ton 4x4 Front End Shaking
sounds tricky. Did you check the braking system to make sure crap isnt getting stuck? im assuming they didnt have abs yet, at least my 73 c-10 didnt lol, thats prolly only on fuel injected models, but just a stab in the dark...
Old 01-30-2006, 05:00 PM
Yes, I checked the brakes as best I know how. No, this truck doesn't have anti-lock brakes. Thanks.
Doug
Old 01-30-2006, 06:46 PM
abaird abaird is offline
Brake rotors may be warped.
2009 Silverado 1500
2002 Camaro Z28(rebuilder)
2005 Yamaha GP1300R
Old 01-30-2006, 07:37 PM
broughy84's Avatar
broughy84 broughy84 is offline
My fire department's 79 Chevy k30 mini pumper did the exact same thing that you are describing. We NEVER could figure that out.....we could never get the carb working right either.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 01-31-2006, 04:09 PM
mbumgua's Avatar
mbumgua mbumgua is offline
I recently had a 84 3/4 ton chevy 4x4 do the same thing. The passenger side tie rod ball joint had been replaced by a shop. When we got it back it did the same thing as the 86 1 ton described above. The solution after a lot of other parts being replaced was to check the toe-in/toe out on the front end. Ours had toe-out of two inches. we adjusted this to factory specs(Basically a small amount of toe-in) and stopped the shaking. We used a tape measure on the distance from tire to tire (front of front tires and back of front tires) to discover the two ich difference. Good Luck!
Old 01-31-2006, 04:12 PM
mbumgua's Avatar
Inch
We replaced bearings, seals, gearbox, springs, shocks, tie rods and balanced the tires.
Old 02-01-2006, 04:10 PM
Smile Re: 1986 Chevy 1 ton 4x4 Front End Shaking
Replacing the drag link ends fixed 98% of the shaking. I think we still need to turn the rotors. The tow in was 3/16”. Thanks.
Doug
