Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 01-30-2006, 08:57 AM
farlowella farlowella is offline
98 Intrepid intermittent problem with headlights
This has been going on for some time now headlights will turn on and off while driving. Recently they turned off and they did not come back on I turned the light switch to off and headlights came on. I turned it back on they went off. What is going on?
Old 01-31-2006, 05:52 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 98 Intrepid intermittent problem with headlights
do you have the auto lamps?
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 01-31-2006, 06:49 AM
No I do not have auto lights
Old 02-01-2006, 09:41 PM
from what you describe sounds like a bad headlight switch.
Old 02-19-2006, 01:36 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Also have your headlamp relay tested
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 04-16-2006, 12:21 AM
Smile Re: 98 Intrepid intermittent problem with headlights
I replaced the dimmer switch from a salvage yard for $40. This took care of the problem. The dealer wanted $120 wow.
Old 10-08-2006, 02:14 AM
Kevin Sontag Kevin Sontag is offline
Hello I have a 99 intrepid. I changed the headlight switch (new), the highbeam stalk(junk yard) cleaned grounds changed relays, checked fuses. traced all of the wiring the car would let me trace. Does the High beam stalk Have the same bad resistance problem you talked about in the car fire on a different posting? I'm guessing I need to keep checking the wires and buy a new stock. Any info is appreciated.
