Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-30-2006, 02:35 AM
discoveryman_2000 discoveryman_2000 is offline
Send a message via Yahoo to discoveryman_2000
misfire
Hello I own a 98 crown vic police modle and i am having a problem with what the computer says is a misfire in cyl 7...I have checked the injectors and changed the plugs....i have spark and fuel and no idea why this is happining....i had a problem with the plastic intake having a crack in the water part but and had to fix along side the road with plastic fusion gel similar to jb weld but for plastic.....could that have contributed to my latest problem and how do i fix the problem...i do not make enough money to take it to a shop or dealer.....please help with advise if you can this is my familys only transportation right now and money is tight.....thank you very much
Old 05-30-2006, 03:15 PM
brooks1018 brooks1018 is offline
Re: misfire
Hi, just found the forum today and have the same code on a '97 P71. Hope you've solvedd your problem by now and would be interested in what it was.
Thanks!
Old 05-30-2006, 05:54 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: misfire
Remove the coil to the missing cylinder and look closely at the plug boot. It just pulls off the coil. If you see any white marks, it means the spark is going through the boot to the head and not through the plug. Also look for cracks on the bottom of boot, or a mushy feel. Common problem on this engine. Also the antifreeze could have shorted out the coil causing it not to fire properly.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 05-31-2006, 12:15 PM
Re: misfire
I replaced the coil to the cyl that reads the misfire and changed the plugs.....still no change...the computer reads misfire on cyl 7....it seems as if its not getting enough fuel...befor it misfires it kind of ligs a little and surges but if i give it more fuel or drop into passing gear it doesnt lack any power....could it be a fuel pressure prob?i also replaced the fuel filter.i know its a simple problem but i dont have alot of experiance on the newer vehicles...
Old 05-31-2006, 12:42 PM
way2old's Avatar
TOKEN HILLBILLY
Re: misfire
I don't think it is a fuel pressure problem, maybe a delivery problem from the injector on #7. They are fairly easily swapped, so move the injector from #7 to another cylinder to see if the miss follows.
