Old 01-30-2006, 12:29 AM
[email protected] jldeising@citcom.n is offline
Bump Stops
Where can I find rear bump stops for a 85, 2.8? They also might be called rear axle suspension bumpers.
Thanks
Old 01-30-2006, 12:40 AM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Bump Stops
Do you mean bushings?. The rubber things around your sway bar? or do you mean Sway bar end links, thin metals rods with bushing on each end that are at each end of the sway bar?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 01-30-2006, 10:12 AM
jcurrieirocz jcurrieirocz is offline
Re: Bump Stops
bump stops are not the bushings.....there the rubber blocks that are attached to the frame so that when or if the suspension bottoms out it hits them and the tires dont rub the fenders or you dont have metal on metal hiting anywere or shocks blowing out.
Im sure they were probably all the sme on all 82-92 fbody cars... ask someone thats parting out a used car or get them from a upickjunkyard probably your cheapest places.
1982 Firebird S/E
1987 Camaro Z28 IROC-Z
Old 01-30-2006, 10:20 AM
Re: Bump Stops
I meant the rubber blocks attached to the frame. I can find the front ones but not the rear.
I'll check the local salvage yard.
Thanks
Old 01-30-2006, 10:55 AM
FormulaLT1's Avatar
Fight the powwa!!!
Re: Bump Stops
Huh, you learn something new everyday. I never heard of them.
Old 01-30-2006, 07:59 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: Bump Stops
I think you can find them on jegs. energy suspensions makes polurethane ones.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 01-30-2006, 10:49 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Re: Bump Stops
They're on 4th gens too but one of mine fell off and I ripped the other one off... :shrug: it was an ounce or so that my car didn't need
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 01-31-2006, 11:46 AM
Re: Bump Stops (Jounce Bumpers)
After doing some research I've found out they are called Jounce Bumpers. The GM Part # is 10164173. I believe they are on all 3rd and 4th gen camaros. The dealer wants $28.00 - $32.00 for one. I didn't see any on the energy susp. site for these cars. There is one for a 76-86 jeep (Part # 99137) which has the same bolt pattern on the web site and looks pretty well the same. It might work. Also a local auto parts store can order them (for jeep) for $21.00 per pair. I might try that.
Thanks
