Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 01-30-2006, 12:13 AM
Boogy886's Avatar
Boogy886 Boogy886 is offline
Question Moonroof Problem
Hey all, I'm a noob and I am having a problem with my moonroof on my 2000 GT. I press the switch to open it, nothing happens...I press the switch to close it(when already closed) and i hear a click(like it's trying to engage), then another, more faint, click about a half-second later(like the switch gave up on trying to close the moonroof.) I searched the forums and saw that the 2000's were having problems with the track. This doesn't sound like a track problem to me at all, but i was wondering if anyone has had the same problem and found a solution, or if anyone had any thoughts.
...All fuses are intact...for anyone who might think I'm an idiot...
Old 01-30-2006, 12:27 AM
808drifter 808drifter is offline
Re: Moonroof Problem
mabye theres a problem with the motor
Old 01-30-2006, 08:07 AM
rodbls's Avatar
rodbls rodbls is offline
Send a message via AIM to rodbls
Yeah, my 2000 GT has the same problem. With mine when i press the button to open it i just push up on the glass and it pops up and works fine. since it really isnt that big a problem for me I havent had it checked out to be fixed, so i dont know what the problem is/solution. Will yours open if you do this? If not yours might be more broken then the rest. Good luck
2000 Fed. Spec GT-"Lafawnduh"
Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp
Old 01-30-2006, 08:20 AM
cficare68's Avatar
cficare68 cficare68 is offline
Yeah agreed I have to push up on mine as well to get it to open
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads.
Old 01-30-2006, 03:52 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
huh.. mine still works perfectly
Don't act like you don't love it.
503/2000
Old 01-30-2006, 09:11 PM
Boogy886's Avatar
nope...doesn't work even if i push on it...oh well im not that worried about it. just one of those annoying little things. thanks for all your input let me know if anyone has anymore ideas.
Old 01-31-2006, 02:14 AM
rodbls's Avatar
I wouldnt say it's a little thing, i mean, its like over a 1k factory option to have it. Plus its real nice to have open in the summer at night. IDK, try a local body shop or something since you probably dont have any warranty. Im interested if nothing else to see how much it costs and what the REAL problem is.
Old 01-31-2006, 07:13 AM
cficare68's Avatar
Make sure the plastic piece that surrounds the switch is pop into place. Sometime mine comes loose and it blocks that path of the switch and it won't open
Old 02-01-2006, 12:11 AM
Boogy886's Avatar
I will have a few different mechanics take a look at it...also i'm going down to mitsubishi tomorrow to get a stupid radio code(ARGH!!!). And i will have a technician take a quick gander at it while im there...i'll keep you guys posted...also another quick question. when i got the car all the moonroof did was tilt, never opened all the way. is it supposed to only tilt back?? did they make one that tilted back and one that tilted back and opened?? it's so hard to word that right, i hope my question is understood...if anyone has an answer let me know. and i will keep y'all posted on the moonroof problem
Old 02-01-2006, 12:15 AM
Boogy886's Avatar
i'm going to mitsubishi tomorrow to get a radio code(ARGH!!). But i willl have a technician take a gander while i'm there. Also my sunroof only tilts back, doesn't open all the way. Is it supposed to open all the way or did they make one that only popped up. The plastic piece around the button is loose but i don't think it's not allowing the button to work, i will take another look tomorrow...thanks for the help guys i will keep you posted.
Old 02-01-2006, 12:16 AM
Boogy886's Avatar
awesome i just posted twice because i got a message saying the first one didn't work...IDIOT! hahaha
Old 02-01-2006, 03:21 PM
Sleepr awd's Avatar
yah this forum is a little odd
good luck with your sunroof/moonroof w/e its called
503/2000
Old 02-01-2006, 06:23 PM
Boogy886's Avatar
cificare was right that plastic piece was in the way...i pressed on it a bit then tried, it didn't work but if i hold the piece up while opening the sunroof it works fine...thanks
