Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 01-29-2006, 10:53 PM
Guff100 Guff100 is offline
Unhappy Constantly having to Change Spark Plugs
I have a 1997 Ford Aerostar, with 225,000 km. The spark plugs have to be replaced every 6 months. Currently the #2, 3 and 5 are misfiring. I've changed the wires and put Ford plugs in 6 months ago. Why is this constantly happening?
Old 01-30-2006, 12:40 AM
RahX RahX is offline
Re: Constantly having to Change Spark Plugs
what do the plugs look like when you pull em out?
Old 01-30-2006, 05:13 PM
truckdude239 truckdude239 is offline
Send a message via AIM to truckdude239
coil or distbutor? if its coilpacks replace the coils
Old 01-31-2006, 08:09 PM
I replaced the plugs today. They looked fine.
Old 01-31-2006, 08:14 PM
occupant occupant is offline
Send a message via ICQ to occupant Send a message via AIM to occupant Send a message via Yahoo to occupant
My van goes through a set every year, but I drive about a thousand miles a week. It never misfires, but it does lose power, when it gets to a point that I can't accelerate past 55-60, I change the plugs and set the timing.
But for a misfire, I'd guess your cap and rotor need changing. Cap and rotor are easy to change, parts are cheap, I'd start there. Especially if your plugs look good when they're pulled.
Old 01-31-2006, 08:50 PM
After I replaced the plugs, the van is again working fine. But like in the past, I am sure in 6 months the van will run rough, the engine light will come on again, and after putting the computer on, it will indicate the spark plugs. Do you still think changing the cap and rotor will help?
Old 02-09-2006, 08:18 AM
I think so. The computer can only tell that there is something missing between the plug and the distributor. It could be the plug itself (they are fine) the wires (you replaced those) the cap, or the rotor. So I'd try those two pieces next, especially since it's so easy to get to and the parts are cheap and probably need replacing anyway. Look for cracks and carbon tracks in the old cap and for wear on the rotor tip and the contact points in the cap itself. If they're clean and look good, then I'm out of ideas.
