Old 01-29-2006, 10:49 PM
s2pidluv4u s2pidluv4u is offline
Help!!!...tranny Problems...
...ok i have a 1995 3kgt non turbo automatic i was driving normally earlier cruising at a moderate speed and suddenly my overdrive (end clutch is it called this?) didnt kick in!!!...so ya it lags then the rpm goes up...so the only way 2 get rid of that problem is turning off the overdrive...is this a bad thing?...i jus had my tranny rebuilt like 1 yr ago...is my tranny f**** up?...how much would it cost 2 repair with labor...i mean my tranny runs fine without the OD...so is my 4th gear messed up?...whenever i turn it on again...it does the same thing RPM goes up and lags...thanks...
Old 01-30-2006, 12:12 AM
StealthModifier StealthModifier is offline
Re: Help!!!...tranny Problems...
so what ur sayin it u have no 4th gear? its like going into nuetral. if thats the case, ur end clutch has gone. i had the same problem with a tranny i pulled outta the junkyard. i ended up returning it since the price of labor was way too much, an just got a rebuilt one.
Old 01-30-2006, 10:12 AM
SthTx3000gtSL's Avatar
SthTx3000gtSL SthTx3000gtSL is offline
Send a message via Yahoo to SthTx3000gtSL
I had the same problem with my ATX I was not a happy camper and I had to have the tranny rebuilt.
'91 3000GT SL
K&N FIPK
Homemade ground wire kit
NGK Iridium plugs
MSD 8.5mm wires
homemade test pipe
Its nice to have an uncle with experience and a shop! Hence all of the homemade shit!
COMING SOON
3sx lightweight pulley
Intrax lowering springs
2 Seat Conversion
