Go Back   Automotive Forums Car Chat > Honda > Integra
Old 01-29-2006, 10:13 PM
andyjs3589's Avatar
andyjs3589 andyjs3589 is offline
Send a message via AIM to andyjs3589
integra vibrating while sitting there
I own a 94 integra gsr w/ 132k miles on it, when I am sitting at a light the car makes a low pitch noise and vibrates not really bad but it is noticeble, then when i rev it up at all or accelerate it the noise/vibration are gone. I have heard that one of my motor mounts might be missing the rubber that prevents the vibration. Is this the probable cause of the vibration and noise?
Old 01-30-2006, 01:40 AM
WReX WReX is offline
Re: integra vibrating while sitting there
does the car have any mods? it could be your lower torque mounts going bad or the mount bolts could be loose
bad mounts is a possibility also as you said
26 PSI anyone?
Old 01-30-2006, 11:20 AM
BobChestnut's Avatar
BobChestnut BobChestnut is offline
bad mounts, bad spark plugs, bad wires.....IACV....idk!
- Chestnut
Old 01-30-2006, 07:00 PM
TurboGSR96's Avatar
TurboGSR96 TurboGSR96 is offline
Send a message via AIM to TurboGSR96
How is your idle?, if it is good id say a motor mount. I got 136K miles on my car and mine were shot at 100K. They become cracked and eventually just fall apart.
R.I.P 00' ITR #479
1996 GSR: Built Bottom - Built Head - Big Injectors - Big Turbo - Computer Thingy - 500+ whp
*2-6-06* Waiting for the Full-Race Stg 3 with GT35R
.82 a/r Upgrade and Nitrous Express NXL
http://www.cardomain.com/ride/2241056
Old 01-30-2006, 09:48 PM
andyjs3589's Avatar
It is completely stock, it idles fine, when cold around 1500 RPM then when warmer 900 - 1000 RPM, Is it hard to replace the motor mounts?
Old 01-30-2006, 10:30 PM
it sounds like bad motor mounts to me
its not that difficult as long as you can safely support the motor and trans
26 PSI anyone?
