Old 01-29-2006, 08:10 PM
harbour1 harbour1 is offline
Civic heater problem
Have a 1988 Civic with a heater that only blows cold air no matter how warm the engine is. Put in a new thermostat, flushed the heater core(flows nicely), the mixing valve opens and closes, and the belts are tight. When I pull off the heater outlet hose (plug engine opening) coolant barely flows out. Is there such a thing as a weak water pump? Or could it be something else? Any ideas are appreciated.
Old 01-29-2006, 08:21 PM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Re: Civic heater problem
You lose any coolant at all? heater core maybe.
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 01-30-2006, 06:19 AM
Hybrid1990crx's Avatar
if the impeller on the water pump wasnt working properly youd be experiencing overheating. are you sure the lines going from the motor to the heater lines are clear?
