Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 01-29-2006, 08:06 PM
zukman31 zukman31 is offline
99 Beetle code P0172
My 99 2.0 Bettle had the check engine light come on. I had it checked and it said the code was P0172 System to rich Bank1 Does this mean the oxygen sensor is acting up?? I had the code erased but it came back on after about 50 miles went back out and then came back on.. and it had the same code again. Has anyone else had this problem and what did you do to fix it??
Thanks for all you guys help
Jimmy B..
Old 01-31-2006, 07:29 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: 99 Beetle code P0172
could be many things : front o2 sensor, carboning of intake manifold / injectors, maf sensor, broken fuel pressure regulator vacuum hose
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 05-09-2007, 05:06 PM
bobby337 bobby337 is offline
Send a message via AIM to bobby337 Send a message via MSN to bobby337 Send a message via Yahoo to bobby337
Did you find out what's the problem. I'm getting the same code today.
Old 05-29-2007, 10:51 PM
dbbyleo dbbyleo is offline
Try posting at groups.yahoo.com at the VAG-COM user group, if you haven't already.
What are you using to pull codes anyway?
