Old 01-29-2006, 07:32 PM
gun nut gun nut is offline
Replacing oil pan gasket-HELP!!
Replacing the oil pan gasket on a 1992 s-10 2.8.The oil pan gasket is one piece and i have took out motor mount bolts and jacked up engine trying to take it off completly but can not do so..Is there an easier way besides pulling the motor???
Old 01-29-2006, 07:42 PM
bigd7315 bigd7315 is offline
Send a message via Yahoo to bigd7315
Re: Replacing oil pan gasket-HELP!!
cut out the crossmember then weld back after finished
Old 01-29-2006, 10:47 PM
Thanks but I'll have to pass on that one..
Old 01-30-2006, 10:34 PM
eti engineer's Avatar
eti engineer eti engineer is offline
Cool Re: Replacing oil pan gasket-HELP!!
I have done this on several trucks, vans included, and if you cannot get the pan off because the oil pump and pickup is in the way, maybe this will help.
The last one I did, I pulled the motor loose from the mounts and raised it as high as I could while it was still in the bay. This allowed me enough room to get into the area in the pan and actually loosen the screws that held the pickup , pump and screen in place. Once I did this, I just dropped the pickup into the pan. The driveshaft for the pump also came out, but no big deal as it was also captured in the pan.
Once I got this stuff into the pan, I was able to remove the pan without pulling the engine.
It is not easy to do, and since I have never had to pull the pan on my '97, I don't know if this is possible. I would consult a Chilton's, Haynes, or better yet, a Mitchell's manual to see what is recommended.
Hope this helps..
later..
eti engineer
Old 01-31-2006, 12:56 AM
OverBoardProject OverBoardProject is offline
Banned
If it's a 2wd that will probably work.
If it's 4wd forget it, you'll have to pull the motor.
If that doesn't work, but the gasket is still in 1 piece I would clean it as much as possible, along with the surfaces (brake cleaner or ether work good for this) then slap on the gasket goop. Put the old gasket back on then.
You should have enough room to do this.
