Old 01-29-2006, 07:06 PM
bluechevelle's Avatar
bluechevelle bluechevelle is offline
Send a message via Yahoo to bluechevelle
Protien/Creatine intake question
I never really thought about using this stuff before but I thought I would give it a shot. I'v done reading on it and know about the loading phase and stuff, and that some say it is goog or bad. I figured I would do the loading phase then the next one, forget what called. i just wanted to make sure I would be doing it right, or close enough.
So I figure I would take 7.5g of creatine in the moring and another 7.5g around 2:00 ( I work out at 3:00) for a total of 15g a day during the loading phase. Then down to like 5g per day for the rest of the time. I wieght 185lbs BTW.
The protien is a little more confusing for me though. Since I weight 185lbs, should I take in 185g of total protien a day, or 185g of suppliment ontop of 185g from food?
Any help is appreciated.
Old 01-29-2006, 09:50 PM
cody_e cody_e is offline
Send a message via AIM to cody_e Send a message via MSN to cody_e Send a message via Yahoo to cody_e
Re: Protien/Creatine intake question
I haven't personally taken creatine but I know you will want to drink a lot more water in a day. Try to shoot for at least a gallon. The creatine will suck a ton of water into your muscles. Also you will gain probably about 5 pounds water weight.
Old 01-30-2006, 11:56 AM
sivic02's Avatar
sivic02 sivic02 is offline
If your looking for size then you need about 185-250 grams of protein each day total. Try to only supplement about twice a day preferably once after working out and once before bed.
I am a fan of the loading phase, it just makes you feel like it is working sooner. Most people say load with 20g a day but 15g should probably do just as well. Make sure when you take it you mix it with something like apple juice, grape juice, or a sports drink as the sugars will increase the ammount of creatine uptake for your cells. Cody is right about the water, keep yourself good and hydrated, a gallon a day will keep your body happy. Good luck man.
Here's to being single, seeing double, and sleeping triple
Old 01-30-2006, 03:23 PM
directory's Avatar
directory directory is offline
creatine...what a waste....
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
Old 01-30-2006, 05:00 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
a gallon of water a day is CRAZY. that is SOOO unhealthy. You will throw off your electrolyte balance AND wreak havoc on your kidneys. Are you trying to make yourself sick? Stick to a few cups a day and remember that many foods contain water as well (fruits, vegetables).
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 01-30-2006, 05:18 PM
OK, thanks guys.
Old 01-30-2006, 07:58 PM
driftinggrifter2's Avatar
driftinggrifter2 driftinggrifter2 is offline
Send a message via AIM to driftinggrifter2 Send a message via MSN to driftinggrifter2
I think the general rule for protein if your trying to bulk up is 2g of protein for every pound you weigh...185lbs=370g of protein
And for the creatine i would say after your loading phase drink a serving 30 mins before your workout then another serving after your workout. I was using this method when i had time to workout and it worked well for me and i am a extremly hard gainer.
F-Bodies Forever Member #2
guess bunny couldnt dominate the world!
Old 01-30-2006, 08:44 PM
Maybe if there's chemicals in the water. How will it screw up your kidneys? Their main function is to filter out bad stuff. Most water doesn't reiquire much if any filtering. I think your kidneys will do just fine. They recommend 8 glasses of water a day for a normal person. A gallon isn't asking much.
Old 01-30-2006, 08:48 PM
He's right they recommend at least 8 glasses a day, the more you drink can't hurt ya(might make you pee alot though)
Old 01-30-2006, 08:50 PM
Unless there are chemicals in the water you'll be fine. I drink probably close to a gallon a day. Make sure that old pee is white. Yellow means you are getting dehydrated and with creatine you DO NOT want that.
Old 01-30-2006, 09:29 PM
i'm not making this shit up. I copy/pasted this: Water intoxication, or hyponatremia, is classified by a critically low concentration of sodium in the blood. Drinking excessive amounts of water can lead to this condition, which triggers symptoms such as fatigue, cramping, nausea, dizziness and headache.
It's not the bad stuff in the water that will hurt your kidneys, but it is the excess WORK it will have to do. A good rule of thumb is your pee should be yellowish and if it is CLEAR, you are overhydrating. Don't believe me, call your doctor and ask.
Clear Corners
Iridium Spark Plugs
Old 01-30-2006, 09:36 PM
Wait I have always been told yellow means you are dehydrating. How is it making your kidneys work hard? Plus that low sodium may be from something else (genetic) and not from drinking water.
Plus you won't pass a hydration test for the skin folds for wrestlign unless your piss is WHITE.
Old 01-30-2006, 09:47 PM
You can avoid low sodioum even while drinking lots of water. If your working out then you are supposed to be eating 4-6 times a day(thats if your trying to bulk) so it all depends on the food you eat for you sodioum intake. Now there is such a thing as overdoing it but it all depends on how you balance everything out. Now you also are't supposed to live of off just drinking water, drink other things as well alot of beverages have decent amounts of sodioum as well. Me personally don't drink more than 11 glasses a day and at least 12 oz of milk.
Old 01-31-2006, 06:49 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
I did creatine for 6 months. The rountine consisted of heavy "blasting" style workouts, 2 hours a day, 5 days a week for the duration of 6 months.
I tried liquid and power creatine during this duration, about 10 drops pre and post workout, and 2 tsp before and after.
The creatine noticeably bulked up my arms, but gave them a "puffy" look, rather than something solid. Over the weeks, I also noted that the area around my kidneys started to hurt towards the end of the 6 months, and my urine was excessively yellow. I used to get up at least 7-9 times in the middle of the night to urinate...this only happened once I had started taking the creatine, and my last heavy doseage of water used to be well before sleep time. Though I had heard of creatines taxing the kidneys, I never though physical pain in such an obvious manner would be a symptom. I quit creatine after those 6 months, and the pain went away, and my urinary troubles quelled also.
Protein did absolute wonders for me. From 165 lbs and 14% body fat, I shot up to 200 lbs at 9% body fat. This was accomplished during another 6 month routine that I followed immediatly after I quit the "creatine infested" trial. I was using CytoSport Muscle Milk, readily avaiable at GNC, Vitamin World, and other places. I have tried many, many different protein powders, but this shake was the best tasting, hands-down (due to it's high fat content, it will taste good, but will also add a little more fat to your body that other shakes, but all is forgiven, considering the other shakes make you barf the minute you get one taste of them; there are more than 15 excellent flavors to choose from too, which makes things easier).
I went through 12 tubs of these in 6 months, and each dose was 2 scoops in a full glass of milk. I used to have this shake 3 times a day, for every single day of the 6 month trial. 1: morning, 2: immediately after workout, 3: right before bed. My workouts were extremely strenuous, which is why the shake helped even more during night time recovery...if you don't work out hard enough, your body will accumulate more fat and less protein assimilation during the recovery phase...
As school got tougher, I lessened my workouts and quit the shake, due to lack of time... I could not sustain my weight, and it fell from 200 lbs to a steady 185 lbs...still better than the 165 lbs I had initially escaped from. 2 years down the line, I am still 180 lbs-185 lbs, even though my workouts are not very regimented any more, which proves that the shakes eally helped with solid body mass.
My advice: work with protein, ditch the creatine.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 01-31-2006, 09:45 PM
That "puffy" look was from the water retained in your arms.
