Old 01-29-2006, 06:40 PM
DWJONZ DWJONZ is offline
replacing 4.3, need a suggestion
My 93 4.3 has 200,000 and a rod knocking, so got a new 4.3 to put in. Now I can't get the engine out because the oil pan hits the 4x4 front axle. I could fight the oil pan and get it off, but then how would I get the new engine in? It would be impossible to get the new gasket and pan back on.
Any suggestions?
Old 01-29-2006, 07:40 PM
bigd7315 bigd7315 is offline
Send a message via Yahoo to bigd7315
Re: replacing 4.3, need a suggestion
cut crossmember on each side of the oilpan with a sawzaw and have someone weld it back when done just did this a month ago on mine the fram won't move when crossmember is cut
Old 01-30-2006, 08:53 AM
herkyhawki herkyhawki is offline
You do not have to remove the oil pan to pull the motor out.
Did you disconnect the engine from the transmission?
Old 01-30-2006, 09:37 AM
OverBoardProject OverBoardProject is offline
Banned
You also might have to remove the motormounts. But not the pan.
If it's standard it's harder than automatic. Since you have to slide the motor forward off the shaft. (or so I'm told)
I would never cut the crossmember. Even if it's stronger after you get it welded the police or safety inspectors might pull it off the road just for that.
