Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 01-29-2006, 03:54 PM
budbowl7 budbowl7 is offline
Fuel Pump Wiring Melting.
After my car left me stranded by not starting, and checking for spark-OK, and checking for the the fuel pump powering up when I turn the accessories on-not OK, I decided to drop the fuel tank on my '97 2DR and go after the fuel pump.
What I have found is a bit disturbing. The wiring connectors at the top of the fuel tank, where the wiring from the truck meets the fuel pump, have very obviously burned and are melted. More specifically, it looks like one terminal of the four is severely burned up. Can anyone shed some light on what may cause this, what I should look for and do, etc? I don't want to throw another wiring harness or pump at this thing only to have this happen again. Thanks.
Old 01-30-2006, 06:37 PM
V8inVA V8inVA is offline
Re: Fuel Pump Wiring Melting.
I had the same problem. I have heard it's fairly common. Mine burnt the contacts of the pump and I had to replace it as well. Dealer sells a replacement harness and crimps as a kit. I think dirty fuel filter causes back pressure and loads the pump, overheating the harness. I change my filter more often now.
Jeff
Old 03-18-2006, 09:49 PM
teknology teknology is offline
Send a message via AIM to teknology Send a message via MSN to teknology Send a message via Yahoo to teknology
those fuel pumps get very hot when you run your tahoe with less than half or quarter periodically. might not have necessarily had burned completely at that time, but gradually. only other cause could be a short.
Old 04-28-2006, 04:49 AM
Bravo Garage Bravo Garage is offline
It is a known issue with the tahoe's fuel pump connector. It is recommended that you change it when you replace the pump. Autozone, Napa, or Advance should tell you that when you go to purchase the pump.
