Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 01-29-2006, 03:00 PM
Jv1985 Jv1985 is offline
Electric & Fuel Problem
I tried to start my 1989 Cutlass Ciera last weak and it didn't start so I thought maybe it might be the starter so I changed it out a couple days ago, I started the car up just fine but when I went to turn on the headlights the car killed over and hasn't started since, although it does turn. I changed the battery with a new one and still got nothing, I have no fuel pressure and None of the interior lights seem to work, already checked all the fuses and they were all fine.
Old 01-29-2006, 03:17 PM
maxwedge maxwedge is offline
A990 racer
Re: Electric & Fuel Problem
Check all the grounds.
Old 01-29-2006, 04:03 PM
checked all ther grounds and even went into an electrical test not getting power to anything other then a few different parts here and there, my alternator, starter, and plugs are getting power but nothing else is, headlights, rearlights, radio, not even the fuel pump is getting power to it.
Old 01-31-2006, 09:53 AM
demo_deven's Avatar
demo_deven demo_deven is offline
Send a message via MSN to demo_deven
There is probably a short or a bare wire somewhere.
Old 01-31-2006, 10:00 AM
87cutlass 87cutlass is offline
Send a message via Yahoo to 87cutlass
You might want to check the fusible links by the starter
Old 01-31-2006, 03:46 PM
A990 racer
Also the power circuit into and out of the ign switch.
Old 02-01-2006, 10:23 PM
Slade901's Avatar
Slade901 Slade901 is offline
Banned
More than likely the remote terminal post. Trace that red wire from your positive battery post and it should be connected to the side just about a feet where the battery is located and there should be a bolt/nut that holds down battery positive cable. If that nut is not tight anymore then it might allow you to crank but once it needs more power, that connection would stop all electrical power to the engine and kill it. So, tighten it up pretty good.
