Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 01-29-2006, 02:31 PM
karnoff karnoff is offline
engine slow to start when warm
i have a 1990 dodge spirit ES 3.0, now in the morning the car starts right up with no problem, but after i drive it somewhere and the engine is warm, it takes the engine a while to start, doesnt wanna turn over right away like it does in the morning, first thing. anyone know what the problem could be?
thanks
Old 01-31-2006, 05:12 PM
Re: engine slow to start when warm
anyone?
Old 02-01-2006, 03:55 PM
jeff compton jeff compton is offline
Do you mean starter just clicking or longer crank time before it starts when it's hot, Sounds like the coolant sensor could be reading inaccurately or maybe the iac is carbonned up or sticking. Maybe a cam or crank sensor problem as well when the temperature gets too it. I suggest looking at the coolant temp readings with both the engine stone cold first thing in te morning and again when it's up to temperature. what's the mileage on your spirit?. keep me postted if you wish
Jeff
Old 02-02-2006, 04:55 PM
its a longer crank time when the engine is warm....mileage is 160,000....i'll let ya know about the coolant readings, thanks for the response
Old 03-09-2006, 12:10 AM
Tuffdrvr88 Tuffdrvr88 is offline
Send a message via Yahoo to Tuffdrvr88
You didnt run any aftermarket exhaust just under your starter did you? Sometimes they will get way too dang hot. Always start with the easy stuff, give it a tune up and see if it helps...don't forget the Fuel Filter.
Old 03-14-2006, 08:04 AM
slantsixness's Avatar
slantsixness slantsixness is offline
If you have the older 3.0 with the bad valve guide problems, it could just be oil in the fuel? Does it smoke like a freight train when you start it?
Easy alternatives:
Clogged fuel filter, failing fuel pump or regulator (but not yet bad), bad rotor, cap wires.
That about covers the 3.0L
Tom
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
Old 04-05-2006, 01:12 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Easy alternatives:
Tom
Slantsixness, long time no see!! Welcome back.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 04-07-2006, 12:39 AM
tony36 tony36 is offline
Send a message via MSN to tony36
Have you thought about vapor locking?
Old 04-07-2006, 02:12 AM
JBS JBS is offline
To me it sounds like you might have a small bit of warpage or a vacum problem due to expanding when the motor heats up.
Old 04-07-2006, 06:34 AM
something else that is possible, coil. It is very common that when a coil goes bad it will act up when it is hot but will work fine when cold.
