Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 01-29-2006, 02:29 PM
Benoit Benoit is offline
Unhappy Radio digital letters dim on & off...
I've driven a 2000 Lincoln LS last two years, two months ago, it the digital
radio letters began to either dim out or disapeared completely... placing some
finger pressure near the cassette eject button, sometime succeeded to
make the digital letters show up again, at time it remained on, but by itself
it went out again, leaving blank (dark ) the monitor...
Any Idea how I could fix this up... instead of getting a newer radio!
Aren't those original stainless steel mufflers supposed to last longer than
any conventional other units.... one of mine shows a 2" crack, dealer told
me one side has to be completely changed at the cost of $1,250 (Can.)
is there a better solution to it, is it possible to only replace the muffler
unit it self rather than changing the whole right side system!
Thank you for your help,
Benoit.
Old 01-29-2006, 08:38 PM
shorod's Avatar
shorod shorod is online now
SHO No Mo
Re: Radio digital letters dim on & off...
For your radio issue, it sounds like you have a bad solder joint internal to the radio. I had a similar issue in my Taurus SHO, broken solder joint which caused the button illumination to stop working. I've heard of others having similar issues caused by broken solder joints in Ford company radios. I suggest you find someone who repairs electronics (either professionally or as a hobbyist) and have them inspect the boards for broken solder joints and stressed vias.
-Rod
