Old 01-29-2006, 01:14 PM
od1exx od1exx is offline
89 lesabre will not run.
alright - this problem just started happening a few weeks ago.
i would try and start the car and usually within a second it would start up, no problem, just like it normally should. however, what i have noticed is that if you don't get the car fully started on the first try you have to hold down the gas pedal to get it to start on any following tries.
so fair enough i figured it wasn't a big problem and i continued to drive the car without any problems until the other day while i was driving down the road at about 70km/h and the car just stalled - i coasted to the side of the road and tried to start it again - no start, the car just cranks over and over without any firing. i tried holding down the gas pedal and still, cranks over but no firing.
btw, when i turn the key i can hear my fuel pump start up and i have checked my spark (just replaced all 6) which is working good.
what could possibly be wrong? i am almost 100% sure it is related to me originally having to hold down the gas pedal in the car but what does that indicate the problem could be?
Old 01-29-2006, 05:31 PM
maxwedge maxwedge is offline
A990 racer
Re: 89 lesabre will not run.
Spray carb cleaner into the intake if it starts, fuel problem, check fuel pressure, if good check for injector pulse with a noid lite, plugs into injector connector if it flashes as you crank, the computer is pulsing the injectors, basic diagnostic steps here.
Old 01-29-2006, 06:14 PM
there is no carb on the car, it is fuel injected.
wud those same basic diag. steps work for a fuel injected vehicle?
btw, i thought i might have a dirty fuel filter or dirty fuel injectors... i'm not altogether sure
Old 01-29-2006, 06:41 PM
TrueLyFE's Avatar
TrueLyFE TrueLyFE is offline
It was meant for a fuel injected vehicle - IIRC the last carbeurated LeSabres were made in '87. At least I believe it is, he mentions injectors. I only know for the most part how it works, not how to work on it (when it comes to engine and engine controls).
Also, the gas pedal shouldn't do anything for you on startup, since it is fuel injected...certainly interesting
'93 Dodge Caravan, 3.0L, A670 - It runs.
'85 Chevrolet Camaro Z28, 305 HO, T-5 - Transmission died! Parked for repairs.
'87 Buick LeSabre, 3.8L - RIP. Lots of blood, sweat, and tears.
Old 01-29-2006, 06:51 PM
truelyfe i know exactly what ur saying and i questioned that myself... how was hitting the gas while crankin it over makin a difference at all? i only wish i knew - anyone have any ideas on that?
Old 01-31-2006, 10:58 AM
hm.... i've been reading around and at this point i am thinking crankshaft sensor, what do you think of that?
Old 01-31-2006, 03:17 PM
A990 racer
Again, does it have spark and injector pulse, there are no diagnostics involved in looking at the most common part replaced on these forums ,basic diagnostics should be done here. See post #2, same stuff again.
