help 96 accent brakes
i have a 96 accent it makes a grinding noise, when braking i took a look at the front rotors and i noticed that it has some grubs on it
i tried to remove the rotors and couldnt. i remove the four screws that hold the disc, now the disc is loose behind the hub. i removed that big nut that holds the cv axel now the cv axle is loose as well the disc, but the hub wont come out i have to replace discs and pads what kind can you sugest ? |
Re: help 96 accent brakes
hey bud you got to use a slide hammer to remove those rotors, sometimes they get stuck right on the hub, thats really the only way, be careful that when you pull the axle nut that you don't pull the cv joints apart...
good luck... |
