Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 01-29-2006, 12:18 PM
MeettheCreeper's Avatar
MeettheCreeper MeettheCreeper is offline
Engine and trans Identification
I have a question that maybe some of you seasoned toyota folks may have an answer for.
I have an 81 pick up, 4 cyl. engine. Where is the stamping on the block that would give me the year it was manufactured? I think but am unsure that it may have been swapped. Also is there a stamping on the trans or a tag that I should look for? Its a 4spd and is going to need a throw out bearing and I want to make sure I have the right one.
Thanks
Creeper
Old 01-30-2006, 07:12 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Engine and trans Identification
There are stampings on the block, but it's in code. A dealer should be able to decode it for you. The TO bearing is pretty standard for all years. I even think it's the same 2WD/4WD.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 02-26-2006, 08:44 AM
SidneyCanada SidneyCanada is offline
These 22R Series tech data may have code definitions for you:
http://www.babcox.com/editorial/ar/ar119838.htm
http://www.babcox.com/editorial/ar/ar400108.htm
http://www.toyotaperformance.com/4_cyl_tech.htm
http://www.lcengineering.com/TechNotes/TechNote48.htm
http://www.toysport.com/Technical%20...tech_notes.htm
http://www.off-road.com/toyota/tech/...toy_motor.html
http://www.off-road.com/toyota/tech/other/4_dts.html
http://www.4x4wire.com/toyota/faq/parts
http://www.geocities.com/MotorCity/P...ct/Engine.html
http://www.toyota-mods.org/engines.txt
http://www.toyotagtturbo.com/engines2.html
http://www.engnbldr.com/ToyotaHotlicks.htm
http://www.bitwalla.com/cruisers/info/engines.html
http://www.off-road.com/tlc/faq/engine.html
http://www.jnc.farpost.com/toytech.html
http://lcengineering.com/TechNotes.htm
http://www.buschtaxi.net/de/01info/motoren.html
http://www.landcruiser.hu/motorok.html
Sidney® ™
Repairs tv's,vcr's,home/car audio out of my home
E-mail:[email protected]
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,solid front straight axle,factory cruise control,sunroof,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 247 000 KM
http://groups.google.com/group/hfx.f...4c696fbf04837f
http://www.iwaynet.net/~nesda/May02/May18.html
http://www.iwaynet.net/~nesda/SonyAudMod.html
http://www.newark.com/product-detail...ge/32-9495.jpg
http://www.tipsmaster.ca/hottips-1.HTM
http://www.tipsmaster.ca/1011-TV32C50-007.jpg
http://www.iwaynet.net/~nesda/June03/June0315.html
http://www.iwaynet.net/~nesda/Apr03/Apr033.html
O
|\ __O
_|_| \
(\__/)
(")_(")
...\....\.._.._../..../....
....\..../....l..`\_./....
..../....l....l....(..`\....
...l.....l.._.l.._.\....\...
...l.....l__.l__.l''\....\..
.....\__________/.....
| | / \ \ \____________ o o )
| | /_________\___\__\__________|_____|
