97 Mazda Protege Vibrates on idle
Hi, I have a 97 Protege 1.5L a/t. Lately it has been vibrating when it idles. Mostly in Drive or Reverse. It now is to the point where it always sounds like it is struggling to run. Also it is being very hard on gas. About 350kms to a full tank. The belt squeels when I first drive off in the morning and it sounds like its going to stall sometimes when im taking off from the second stop. Any suggestions?
Re: 97 Mazda Protege Vibrates on idle
sounds like a vacuum leak to me. check your intake ait tube coming of your throttle body
This is a common problem for this motor. Some of the usual culprits:
Dirty throttle plate on throttle body. Egr malfunction Dirty PCV Poor compression in one or more cylinders. The first three can be fixed for a $1.89 worth of carb cleaner and 1 hour of your time. Let's hope it's not the fourth... |
Vibrating has stopped. I took it to the garage and it turned out it needed an air flow sensor. Runs much better and it no longer vibrates. But still.. the car is extremely hard on gas. I got 250kms to the last tank of gas, thats about 150miles. This is ridiculous the car only has a 1.5. The air filter is also brand new. What could be causing this?
