Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 01-29-2006, 01:01 AM
vali31 vali31 is offline
1997 Yukon
Hi! When i drive my Yukon on the freeway at exaclty 70 mph the truck starts to shake. Also when I get off the freeway and into residential areas, when I stop and then go I get a hard jerk when I accelerate. Any help please.
Old 01-30-2006, 08:18 PM
bryfry bryfry is offline
Re: 1997 Yukon
Sounds like a u-joint problem, vali31. Probably the rear most one. Very common problem on GM trucks. Precision makes a pretty good u-joint and most parts stores carry them in abundance. The worse case scenerio is a worn out pinion bearing in the diff. You may want to get it up in the air at a shop and have someone qualified check it out.
Old 02-01-2006, 01:50 AM
Re: 1997 Yukon
Thank you for your help I will have it checked.
