Has anyone installed wiring themselves to a stereo amp back to the trunk. I'm also running RCA cables from the stereo. If so, how did you run the wires to hide them in the neons? Would like any tip from anyone.
Re: Stereo system in Neons.
hey man i have a completely custom wired setup. what kind of neon do you have? if you have a 95-99 neon i can help you out. its fairly easy to wire up.
Im not sure what the power in watts the amp is i am picking up the system on the 3rd of FEB. What if the amp is 400 watts, and i have the 225 watt wiring system. Can i get away with that for a while. I will let you know more this weekend when i inspect the equipment. I would love to know how you have your set up. Tips are great. Crutchfeild.com is a pretty good sight for help for me. If i have 2 subs, i was thinking about wiring the left 6x9 in series with the left sub and the same for the right side also. that is if the amp is at least 250 watts. Is this a good idea or not? |
hey again ill put pics of the sytem and info later. . but it is prolly best just to send your rca s to the other side of the car to prevent unwanted sounds. also to run in series a sub and 6x9 will cause a little headache cause of the low wattage and the fact that you are trying to push treb in a sub which is not what it is built for. you could go out and pic up a bass treble splitter that will send bass to your subs only and treb to your 6x9. this will have you lose out on the bass created by your 6x9. my suggestion is to run 6x9 normally and yoursubs on your 400. as for you 225 you will only get as much power as your weakest link in the setup. soo you have 225 watts. tommorow i will put up a diagram and pics of my setup which has taken close to 1 year to perfect and finish soo i will at to this later ok. hope that helps for right now alright. have fun.
I ran the wires under the doorsills, under the back seat and into the trunk. I got the AMP mounted on the back of the backseat
hey, i'm just wondering if u wired u'r stereo up yet, if not and you need some help, i know a bit on wiring systems up..
