Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-28-2006, 08:26 PM
gjgardner gjgardner is offline
Reprogram 96'keyless entry fob?
How do I reprogram my keyless entry fob for my 96 mustang?
Old 02-05-2006, 04:18 PM
motorjock205's Avatar
motorjock205 motorjock205 is offline
Send a message via MSN to motorjock205
Re: Reprogram 96'keyless entry fob?
in the left side of the trunk behind the panels, you should see a black box mounted inside there...there should be a gray plug that you will need to short accross with a screwdriver. Once you short the prongs in there, the door locks should lock...press the lock and unlock on your fob and the locks should lock and unlock again. Key fob should be re-programmed then...
Forget World Peace, Visualize Using Your Turn Signals!!!
Carl W. Ervin
2008 Shelby GT CSM 08SGT0235
Old 02-06-2006, 06:37 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
