Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 01-28-2006, 08:08 PM
northwest_choppers northwest_choppers is offline
1990 Beretta Put in gear and it stalls
We just bought our son an 1990 Beretta it ran good but when we got almost home it would die at the stop light and it starts back up but put it in gear and it dies. Any help would be great!!
Old 01-28-2006, 10:04 PM
jsgold jsgold is offline
Re: 1990 Beretta Put in gear and it stalls
TCC solenoid. (Torque converter solenoid) When the car gets warm it causes the car to shake and shudder when slowing down, stalls out. Starts up OK but stalls again in any gear until it cools down. It is a pain to replace even though it is a cheap part (in transmission) because in most Berettas and Corsicas it is just plain hard to get to. Test this by unhooking the 4-prong plug going into the transaxle. The car should stop doing this if unhooked. Can drive the car with it unhooked if you want(most do) but you will lose a little gas mileage as your car will run a little more rpm to go. The car will shift OK but it will feel like the overdrive is no longer working. Again, most people leave it alone, but, you can get it fixed for 150-200 bucks at most transmission shops. You might be able to replace it yourself, but I do not think on the 1990 model you can do this easily. If your car is a 3.1 the connector sits underneath the air filter box. Remove the filter housing, filter,and then the base. Should be able to see after that.
I used to be indecisive, now I am not so sure.
Old 01-28-2006, 11:10 PM
DUDE !!!!!!!!!!!! You ROCK !!! you nailed the exact problem.............. you even knew how it was acting !!!! .....butttttttttttttt where the hell is the breather box suposed to be ???? this car has a Cold air intake and, and , and ALOTTTTTTTTTT of performance parts........
I will try your problem solving tip in the morning....... IF,,,, I Can locate the wires you talked about .....
Thanks again.........
Tim @ Northwest choppers
Old 01-28-2006, 11:24 PM
I assume then it IS a 3.1 (cold air intake on a 2.2 would not be likely). I will also assume it is a multi port fuel injection. If so, it should be visable failry close to the area near the throttle body (front of engine) Remove the intake. Look for a round pc of metal with a threaded hole in it. This is where the old filter housing bolted down. Should be right under there...
Old 01-30-2006, 12:17 AM
Well The car now runs like a Champ ! no more stalls !!!! Thanks again for the tip on the UN plug !!! We will be fixing it the Correct way ......but for now this is working great !!!
