Go Back   Automotive Forums Car Chat > Dodge > Daytona
Old 01-28-2006, 07:56 PM
grodrianst grodrianst is offline
Send a message via AIM to grodrianst
Turns Signal Help - Please
Have an '86 Laser 2.5, the turn signals seem to work okay other than blink slightly slow. However, when the parking or headlights are on the signals light up but don't flash. I have replaced the flasher cannister with the same results. Thoughts or suggestions?
Old 01-29-2006, 10:10 AM
AWP9521 AWP9521 is offline
Re: Turns Signal Help - Please
Check the ground connections at the rear of the car for both sides and make sure they are good, if the turn indicator lights on the dash are lighting when the parking or headlights are on then check the ground connections in the front as well.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
Old 01-29-2006, 07:24 PM
Thanks, will give that a try.
