01 Eclipse GT Limited Slip Diff.
Does anyone know if the 01 Eclipse GT has a limited slip differential. Im looking to buy one and I want to know.
Thanx |
Re: 01 Eclipse GT Limited Slip Diff.
Yes there are a couple of companies that make a LSD for the Eclipse. Please use the search feature becuse this has been discuss before and check the the sticked post on the main pageof this forum
2006 Mitsubishi Eclipse GT Debagged, 18" MKW Rims, 5% Tint, Ralliart Eyelids, Outlaw Racing IM and TB Spacers, Ingals "Stiffy", Energy Suspension Polyurethane Motor Mounts, Tanabe Lower Tie/Strut Bars, Progress Rear/Eibach Front Sway Bar, D2 Racing Lowering Springs, RRE Headers and Axelback, AEM CAI w/ Bypass, 12000k HID Heads, 3000k HID Fogs, Sunroof Wind Visor, Drilled/Slotted Front/Rear Rotors, and Ceramic Brake Pads. |
no they don't come with a lsd from factory. You pretty much have two options for an aftermarket lsd, Kaaz and quaife. If you're interested in the quaife you'll have to check because some years had different axle splines and it wouldn't make a good seal in the lsd and it would leak tranny fluid. I'm not sure if Quaife fixed this problem but you'd have to call and ask or get the axles that fit. Mine fit with no problem but others have had problems with the tranny leaking. It doesn't seem to fit a pattern either because it some cars of certain years leaked but others of the same year didn't.
id go with KAAZ just because ive used them alot for drift cars ive elped build and tey havent let me down yet.
This is a LSD for a FWD right, meaning, it gets installed in the tranny? Is that correct?
-DAVE |
pretty much, i've heard great things about quaife though, they will replace the differential even if you blow it during racing, which isn't easy to get most companies to do!! kaaz isn't bad though, i've heard of some satisfied people with them, its just my personal preference and i don't ever remember this being discussed before, might have to add this to the main top thread
![]() Don't act like you don't love it.
503/2000 |
i might try adding a few eclipse specific things as well
503/2000 |
503/2000 |
i don't understand how it could be that far off. i wrote the topic in this specific software, checked to make sure everything was correct, copied it to a text file, and sent it to you. i don't understand how all of the formatting was removed.
I was looking online for a LSD. Does anyone know of a good sight to look for one?
MODS: 2001 Mitsubishi Eclipse GT Spyder,17" Konig Wheels, AEM Underdrive pully and Air Intake System, B & M Short Shifter with MOMO boot & shift knob, High Performance Drilled & Slotted Roters w/Hawk Brake Pads, Centerforce Stage 2 Clutch, Fidanza 9lb Flywheel and a Magnaflow Full Catback Exhaust System. |
