Old 01-28-2006, 05:30 PM
I-ROC KID I-ROC KID is offline
aluminum vs steel heads
which is better i know aluminum cost way more becuase there suppose to be AHHH god like or something but i was talking to this guy today at a proformance shop and he was telling me that steel ones are cheaper and can make more power then aluminum ones so according to what i have heard its the other way around but im just making sure im not wrong
355 small block 4 bolt, 700R4 tranny/w shift kit, elbrock 650 carb, elbrock intake, mild cam, 3.73 posi rear end, 3" cowl hood, 3" exhust, b&m mega shifter, k&n air filter, ac delete
Old 01-28-2006, 05:33 PM
poormillionaire2 poormillionaire2 is offline
Re: aluminum vs steel heads
Uhhh...All I know is that the steel would be heavier than the aluminum. I think the steel would absorb and retain more heat also. I think its a potato -'patato' thing.
Sold
1994 Camaro Z28
Current Car
2003 Monte Carlo SS
Sold
2009 Kawasaki Ninja 500R
Old 01-28-2006, 05:40 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Aluminum is 4 times better against heat soaking than Cast Iron head. As we all know cooler denser air makes more power. While sometimes Iron heads tend to have slightly higher flow rates aluminum heads tend to get smoother ports and are easier to port. As they are a softer metal. Most high performance machines get aluminum heads for a reason.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 01-28-2006, 06:22 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Aluminum!!!!
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 01-28-2006, 07:28 PM
so theres good and bad with either one.. which would u do is aluminum really worth all the money
Old 01-28-2006, 07:38 PM
Mr. Luos's Avatar
Firebird Guy
I wouldn't put iron heads on one of my motors if given the choice.
Stock'ish'
Old 01-28-2006, 07:39 PM
FormulaLT1's Avatar
Fight the powwa!!!
Depends on many things which is better for you and what the cost difference is.. I already had aluminum and would not think of putting cast iron on them. Alot of the impala and caprice guys with Iron headed LT1's tend to be laying down the cash for F-body and corvette Aluminum LT1 heads but you will hard up to find the opposite. I know aluminum cost extra but to me its worth it in most performance circumstances.
Old 01-28-2006, 08:29 PM
Morley Morley is offline
Alumnium heads allow you to run higher compression ratios due to their superior heat rejection, as in they shed heat very quickly and this helps prevent detonation. Iron heads tend to hold heat which is not desireable bacause the air charge in the cylinders will be heated by it and cause detonation.
Old 01-28-2006, 11:43 PM
stepho stepho is offline
Send a message via AIM to stepho Send a message via Yahoo to stepho
Heres my two cents..
Aluminum heads are lighter smoother but have a lower melting point.
So basically Aluminum heads are better for proformance and iron heads are stronger.
You have to be careful when removing aluminum heads too because you can damage them way easier than cast iron.
I had to have my aluminum heads machined, in my lt1, because the car had been over heated and the heads warped. (before i got it)
Originally Posted by sportlinetta
lol, u guys are dummmmmmmmmmmmb im 14 n i know more. i gotta 88 camaro.
would that mean get a new cylinder or plug???
Old 01-30-2006, 02:29 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
amunimum all the way, there lighter and dont retain as much heat
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 01-30-2006, 11:09 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
a point i haven't seen said yet... you can actually lift an engine from the heads if they're cast iron, which is sometimes a big help...
alot of nitrous junkies i've talked to prefer cast iron heads... you can run sick amounts of spray without causing the heads to lift... which sometimes happens with alluminum heads... sometimes they'll see coolant on the outside of the engine cuz the heads will lift up and cause the water jacket to leak... if i were going to run a huge shot of nitrous i would definately go with cast iron, but they do hold heat longer and transfer it much slower...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 01-31-2006, 11:54 AM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Go with aluminum!! there was an article on this
same exact heads except one was cast iron the other was aluminum. same port sizes runners valves everything and the aluminums made 40 more hp on the dyno
Old 01-31-2006, 11:56 AM
And with aluminum you will probably be shaving off 80 lbs where its needed
Old 01-31-2006, 12:35 PM
1986Z28's Avatar
Has a Camaro
when i did the lt1 swap on my caprice, i sprung for corvette heads, well worth the the money
Old 01-31-2006, 03:05 PM
victimizati0n victimizati0n is offline
Send a message via AIM to victimizati0n
you ONLY need aluminum heads if you are RACING your car.
if your not, they are totally useless.
