| Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models |
almost got the problem solved just need a little help
My car jerks and stalls when cold and doesnt when warm but has a rough idle. now when its warm and i pull the oil fill cap off it does the exact same thing as when its cold. any ideas whats wrong?
1992 oldsmobile 88royale btw |
Re: almost got the problem solved just need a little help
Clean the throttle body and maf sensor. Check the pvc valve and check your hoses that are on your throttle body or around that area for leaks. This is a start. Oh, and check the computer for any codes that it might have stored.
cleaned the throttle body today it cleared it up now i got a code 22
You probably already had the codes stored in the computer before you cleaned it. Code 22 means the throtle position sensor voltage is low. You need to replace it and when you do, you have to adjust it. Did you clean the maf sensor (you clean it by spraying throtle body cleaner on the "2 wires" on the bottom of it)?
cleaned the maf with electric parrts cleaner
how do i adjust the tps when i get a new one?? also does it have a motor and move by itself or does it sit on the throttle n when i hit the gas it moves with it???
the sensor moves with the throttle body. so when you jam down the gas, the a lever pushes a bar, turning the sensor.
jerking came back again today
Just a quick thought,change the wires and plugs (AC DELCO).
plugs and wires are about 3 months old coil pack is about 4 months old has new maf 2months old also new pcv valve the car is still jerking and stalling on me no codes for it either. could it be that sensor under the throttle body thats like a coolant temp sensor or should i rule that out and go change my valve covers ( the front one hte nub for the oil cap is stripped and it doesnt stay in firm and when i pull out the oil fill cap it gives it a really rough idle so i figure im loosing pressure somewhere any places i should start checking??
thanks |
