Old 01-28-2006, 05:21 PM
wethepplebmxer wethepplebmxer is offline
warning lights... help
i got the ABS and "check tire press" lights on, i looked it up and both on at the same time means my tire pressure system isn't working or somthin. What's goin on and what needs to be done?
The GTP's Kill list:
- 07 Impala SS
- 06 Cobalt SS S/C
- 00 Mustang GT
- 06 Charger R/T
- 90ish Prelude (modded)
- Eclipse GTS
- 03 or so Civic Si
- 96 Eclipse GS-T (some mods)
- 04 WRX (manuel)
- 94 Prelude V-tec (head, cat, more...)
- 06 WRX
- 96 T/A
- 05 300C
Mods: Thrasher CAI, 3.4 pulley, straight pipe (res and u-bend delete), ZZP PCM, Colder plugs, new wires, 180 t-stat.
Old 01-28-2006, 07:37 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: warning lights... help
Generally it means that you have either a low voltage condition, low tire or a bad wheel sensor. Unfortunately, the wheel sensor is part of the hub assembly and they are not inexpensive to purchase. I would take it to a mechanic that has an ABS capable scanner to scan the system to find out what is going on. I believe you have a bad wheel sensor.
Old 01-29-2006, 12:46 AM
nooooot what i wanted to hear...
- 07 Impala SS
- 06 Cobalt SS S/C
- 00 Mustang GT
- 06 Charger R/T
- Eclipse GTS
- 03 or so Civic Si
- 04 WRX (manuel)
- 06 WRX
- 96 T/A
- 05 300C
Old 01-29-2006, 09:00 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
sorry about the bad news, but I agree with GTPDad, it's most likely a bad hub. You'll need an ABS capable scanner to narrow down which one is bad.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-29-2006, 11:49 AM
is it safe to drive?
- 07 Impala SS
- 06 Cobalt SS S/C
- 00 Mustang GT
- 06 Charger R/T
- Eclipse GTS
- 03 or so Civic Si
- 04 WRX (manuel)
- 06 WRX
- 96 T/A
- 05 300C
Old 01-30-2006, 04:00 PM
richtazz's Avatar
As long as the the bearing isn't causing a vibration, or making a grinding/humming noise, it's safe to drive. Just be sure to adust your driving habits for bad weather conditions, as your ABS will be inoperative.
