Go Back   Automotive Forums Car Chat > Buick > Regal
Old 01-28-2006, 03:30 PM
chevy110_1 chevy110_1 is offline
HELP!!! 91 regal lights not working
I have a 91 regal i just bought for $950cad with 117000 KM but the headlights, tail lights, and dash lights dont work. Dome light works dims and everything. I changed the switch anyways and they still dont work. Any help would be greatly appreciated.
Old 01-28-2006, 07:27 PM
tomogchi tomogchi is offline
Send a message via AIM to tomogchi Send a message via MSN to tomogchi
Re: HELP!!! 91 regal lights not working
Easiest way to do this.
Run a positive wire from the battery and splice it in with the..........pink or orange wire to the headlight switch. Now i say splice because i tried just connecting it, and it didnt work, so i spliced it and it did work. Now considering im not sure on which wire it was, Buy a haynes manual, or have one of these wonderful folks hook you up with a headlight wiring diagram. (btw, the headlights are also ignition controlled (least in my 91 regal), so they may not turn on while the ignition is off.)
Bill
Old 02-13-2006, 10:19 AM
hey thanks for the advice. it got my mind going and I found the problem. Look under your rad support and there will be a bunch of wires in some loom. There is a thick red wire and has corroded away. Cut the wire 3 inches on either side of the corosion and re wire the little section and you will have lights. With no wire running from your battery.
