Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 01-28-2006, 03:25 PM
CHEVYdriver89 CHEVYdriver89 is offline
Send a message via AIM to CHEVYdriver89
Air Box
Hey, I want to replace the tube that leads to the air box in an '01 Impala, can someone tell me a good way of getting it off or getting the air box open?
Old 01-28-2006, 05:28 PM
bigrod118's Avatar
bigrod118 bigrod118 is offline
Re: Air Box
yeah, take off the ring clamp and pull. its not very hard to figure out how to take out the bellows, or the air box.
Old 01-29-2006, 08:12 AM
57chevyragtop 57chevyragtop is offline
Send a message via MSN to 57chevyragtop
Re: Air Box
I know others have done so to install cold air intake but I am curious as to why you want to do this + replace it with what?
I do think the engineering on the factory boxes is the worst I've seen from GM. But then the entire engine bay is a screwed up layout from wiring layout to moisture holding pockets ie: strut towers etc. Hope they did better on the 06's, I haven't seen these yet.
Old 02-02-2006, 11:30 PM
Pat_OD's Avatar
Pat_OD Pat_OD is offline
Re: Air Box
i took out the headlight and sawzaw'd the airbox in the front above the CPU and its gets better gas mileage, better pickup on highway, and sounds throahty when accelerating. I have the 3.4 but the airbox on a 3.8 should be the same.
Old 02-15-2008, 07:52 AM
impalalover impalalover is offline
Re: Air Box
exactly where did you saw the box
Old 08-26-2008, 10:05 AM
Re: Air Box
Can you take some pis of where you cut the end of the airbox off,i tried to take my box off but there is a wiring harness there that seems to be inside it that does'nt pull off
