Go Back   Automotive Forums Car Chat > Buick > Regal
Old 01-28-2006, 02:45 PM
Cantankerous's Avatar
Cantankerous Cantankerous is offline
92 regal door assembly
Can anyone help me out with replacing the drivers door assembly mechanism under the cover assembly? I broke off a piece of the mechanism just opening the door. anyone that has done it before any info would be very helpful
Old 04-04-2006, 06:58 AM
raybuick raybuick is offline
Re: 92 regal door assembly
Okay, lets start off by removing the cover totally-disconnecting electrical connections if any. --two main screws behind inside handle
If you are replacing a damaged door handle, there are 2 screws accessible from the inside,one maybe thru a plug hole. Then theres the linkage that goes down to the latch. Its tight in there and you may need a flashlight to see how everything connects, Good luck
Old 05-21-2006, 07:40 PM
Thanks for you help it's done
