Old 01-28-2006, 02:33 PM
jjstorm32 jjstorm32 is offline
01 GA SE Won't Start! Turns over in Neutral& Shuts back off
Reset the system...took the battery off for 24 hours,changed both the Crank and cam sensors.2.4 Quad...by the way.Can't find a pressure release on the fuel line,so I disconnected the line at the fuel rail and their is enough pressure to blow your finger off.Won't turn over in Park,but will turn and fire in Neutral,then just cuts off.No codes pop when hooked up to the PCM.Acts like the Damned security system,but when I reset the system,still have same trouble.Don't have a ton of $$$ to put into it,but need it up and running quickly.....Could it be the Neutral Safety Switch? Tested the Ignition Module,checked OHMs on the coil Pack,checked all the relays and fuses.Car was running normally.Left it idle and when I came out of store after three minutes,car had died,and hasn't run since.Any help in this matter would be appreciated.NO check engine light or any other idiot light is on or comes on during the ignition process...except the security light after the key is turned.Car has been running like a top and have had no trouble at all prior to this.No lights or warnings.
Old 01-28-2006, 06:31 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 01 GA SE Won't Start! Turns over in Neutral& Shuts back off
This is a passlock issue. When you say reset did you reset the PCM or the passlock system? If it was the pcm then you need to reset the passlock system by setting the e-brake and then turn the key on for 10 minutes, turn it off for about 10 seconds and repeat 3 times. On the third time try to start the car. Make sure to use an original key not a copy.
Welcome to AF!
