Go Back   Automotive Forums Car Chat > Fabrication & Tools > Metal Shaping and Welding
Metal Shaping and Welding Discuss metal shaping and welding techniques. Share your projects or tips and tricks.
Old 01-28-2006, 01:43 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Rolling ridgid copper tubing
Anyone know if you can roll ridgid copper tubing? (the hard kind, not the soft kind). I'm wanting to roll some 1/4 or 3/8ID on a 6" inner radius, not sure how the tubing will respond to it though.
Old 01-28-2006, 06:05 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Rolling ridgid copper tubing
My suggestion would be to do it in two halves, then weld the two halves together with TIG and copper filler rod. Find a brake rotor, or round weight for bench pressing the correct diameter. Weld it to a table. Take a bolt, and weld it about .5" away from the disk onto the table. Stick the tube in, use some heat from an o/a torch, and bend one half. Rinse and repeat.
-Mike
Old 01-28-2006, 07:24 PM
Forunn Daberator
I was going to run it though a ring roller.
Old 01-28-2006, 09:34 PM
mike@af's Avatar
I thought about mentioning that, but after speaking with you I chose to suggest the most interesting method.
-Mike
Old 01-31-2006, 01:36 PM
astroracer's Avatar
astroracer astroracer is offline
A ring roller will just flatten and kink the tube. You need to run it through a real tubing bender like this...
I don't know if dies will be available in the diameter you need though.
Does it HAVE to be copper? Galvinized conduit is easy to bend and it can be done with a hardware store tool.
Old 01-31-2006, 06:40 PM
Forunn Daberator
I have a tubing bender, but I'm not going to buy a die for 3/8" pipe for it. I'm going to buy some and run it though my ring roller, It has dies for 3/8" bar, if I keep running it though I dont think I'll have a problem with kinking.
Old 02-01-2006, 07:14 AM
astroracer's Avatar
Keep us in the loop...
Old 02-01-2006, 03:35 PM
Forunn Daberator
Sure thing, If it doesnt work I can allways use soft copper tubing. As for the question "does it have to be copper?": it doesnt have to be, but the only reason I'm trying to do this is because I like the look of copper.
Old 02-16-2006, 09:34 PM
customandsound customandsound is offline
Send a message via AIM to customandsound Send a message via Yahoo to customandsound
i have one of them made me a ton of cash and took a lot of guesse work out i have used it to bend exhaust pipe to
Old 02-16-2006, 10:50 PM
Forunn Daberator
If you know how to calculate degrees and know how to mark your dies at where the bends accually start they are pretty easy to use.
Old 02-16-2006, 11:01 PM
i bend dom tube for cages it got simple to use after 4 years of doing it
Old 02-17-2006, 10:53 AM
Forunn Daberator
OH MY GOD YOU BEND DOM TUBE!??!?!?! Will you be my hero, no wait... will you be my god?
Old 02-19-2006, 09:47 AM
what are you going to use them for.... Has anyone used Eastwoods ring roller ?
