Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 01-28-2006, 11:48 AM
loganlott loganlott is offline
Question lugging feeling when in gear
My 03 ram 4x4 has a lugging feeling when you put it into gear it almost feels like the clutch is barley slipping could that be what it is?
Old 01-28-2006, 11:58 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: lugging feeling when in gear
A little better discription would help.
Is the engine pulling down or is it speeding up?
Std trans? All gears or just when you put it in gear?
MT
Old 01-28-2006, 12:05 PM
auto trans and yeah it is pullin down but i forgot to mention and i'm sorry but it only does it when you let off the brake and let it idle out the driveway or down the road. But once you accel it clears up.
2005 Chevy Z-71 Ext. Cab
2003 Dodge Ram SLT 4x4 Laramie QuadCab
2000 Chevy Camaro SS
Old 01-28-2006, 12:27 PM
MT-2500's Avatar
AF - Advisor
Look over your tune up end. Plugs,fuel filter,fuel pressure.
And have it checked on a good scanner for codes and data reading.
MT
Old 01-28-2006, 12:38 PM
ok bud i'll do it is just bought the truck it has 78,000 miles on it but i'm sure the plugs ain't been changed in a while so i'll change em today. Thanks
Old 01-28-2006, 12:40 PM
MT-2500's Avatar
AF - Advisor
You will not get much get up and go out of it if you just let it idle down the road in gear.
You are going to blow the computers mind doing things like that.
It may think it is still sitting still.
They are made to put in gear and give them the gas to get them going.
Try giving it some gas and if it goes ok problem solved.
Depending on your mileage check tune up and fuel filter if it has one.
Some do not.
MT
