Old 01-28-2006, 08:04 AM
gade600 gade600 is offline
97 chevy blazer lost power and died
Just shut down, while driving, when i finally got it off the road, tried to restart it, noticed the fuel pump making a different noise than usual.....
alot duller of a sound, not the higher pitch wizzing sound it normally makes...
Im thinking its the fuel pump (gone) again, have done 2 on this vehicle in the last 5 years. How much if any, pressure should i have comming outta the pump??
thanks, its my first time posting too
Old 01-28-2006, 07:38 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: 97 chevy blazer lost power and died
You should have 60psi at the shrader valve... If you don't it's most likely the pump.
Do you often let your tank run close to empty?
Old 01-29-2006, 07:43 AM
After replacement of the last pump i try to keep the fuel levels higher than a 1/4 tank, im gonna get a pressure gauge today and test that out.....
now dropping the tank to replace?? are there special tools needed to release the fuel lines from the pump??
thanks for the reply
Old 01-29-2006, 07:51 AM
rlith's Avatar
Use actual line wrenches when you remove the lines. That way you don't risk stripping the corners...
Old 01-29-2006, 04:56 PM
Thanks, got myself a pressure gauge, only had 15 psi, changed out the pump, $299 later, i have it running like a top now...
thanks again
Old 01-29-2006, 04:58 PM
rlith's Avatar
thanks again
Good deal man!
