Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-28-2006, 05:52 AM
onegoofywar's Avatar
onegoofywar onegoofywar is offline
Electrical Problem Mirrors/Lights/Wipers
Wonder if anyone has suggestions concerning an electrical problem for my 2001 CV.
My remote control mirrors haven't been working (not a fuse) for sometime now. Recently, however, the wipers don't come on immediately and won't return all the way down when shut off. Also, the auto headlamp switch can't be turned off- the lights come on all the time.
Does anyone know if there is a module for these, maybe for the indtrument panel, that may be the culprit?
2001 Ford Crown VIc LX Auto OD Traction Ctrl
1994 BMW 540i Auto
Thanks! Jeff
Old 01-28-2006, 06:10 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Elecrtical Problem Mirrors/Lights/Wipers
That may be about 3 seperate problems unless you can find a bad power feed or ground connection to all 3 of them.
Fuse 11 feeds mirrors and wipers/multi function switch and auto headlights but also feeds some other stuff. You might check it for good full voltage on it.
You will need the NGS ford scanner to get into much on the auto headlight stuff.
A good eng/body pcm capable scanner may pick up some body codes.
Are you going to attempt to fix it yourself?
If so you are going to need some good repair info like factory manual or something like a all data diy sub.
Link below for the online all data DIY sub. runs 24.95$ a year
http://www.alldata.com/products/diy/index.html
MT
