Old 06-18-2002, 07:48 PM
kholly kholly is offline
Unhappy 95 Civic hesitates REAL bad
I have a 95 Civic LX with 190000km. A while ago, the engine developed a hesitation while accelerating where it would seem like the ignition was just cut. Lifting the accelerator would bring the engine back to life. Hot or cold, didn't seem to matter, but at high revs, it never happens. I can hold it right up to 150 plus and it just keeps pullin'.
Only at low revs, ESPECIALLY when leaving a stop, is when it happens. The problem has gotten so bad now that it's hard to start, and if I just sit in neutral and slam the accelerator, I can stall it at will. I don't even drive the car now because it's so bad and I've been stranded once already.
I've had a mechanic friend with access to a scope check some of the sensors. He said the CPS was bad, so I replaced it. No change. I replaced the ignitor, no change. MAP sensor checks out okay with the scope. Injectors continue to pulse even when the engine is dying (checked while purposely stalling in neutral). Replaced fuel filter, no change. Distributor cap looks okay.
The are two things I'm considering testing or replacing: the coil and the injector relay.
Does anyone have any other ideas or comments on these next two 'experiments'?
Much thanks in advance....
K
Old 06-18-2002, 09:37 PM
drive drive is offline
Have you tried asking Jim he knows every thing.
Old 06-19-2002, 03:06 PM
Mirt3 Mirt3 is offline
Send a message via AIM to Mirt3
is your ac on? mine does that when its on.
-Mike
Old 06-19-2002, 05:02 PM
b16a3sol b16a3sol is offline
the coil is where i would look first. make sure that it is putting out enough voltage to make the plugs fire every time. also make sure you are getting enough fuel pressure. also make sure your injectors are flowing enough fuel. if you have never had your injectors cleaned, now would be a good time. good luck.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
Old 06-19-2002, 10:08 PM
Xplocivic's Avatar
Xplocivic Xplocivic is offline
Send a message via AIM to Xplocivic
Mine hesitated for awhile, then i changed out the plugs for Bosch Platinum 4's and now it runs like a champ! Try new plugs and wires.
Boosted Civic, 211hp on stock D16z6
Old 06-20-2002, 12:03 PM
Fuel pressure has been checked. Coil is the next thing I will try, a friend has one that I can swap just to test....
I'm steering away from injector clogging simply because the car pulls well at high speed and the hesitation is so distinct that it feels like someone has cut ignition power abruptly. The coil is that last thing to check here (other than plugs and wires and computer). Next step will be injector relay if this doesn't work...
Thanks for the replies....
K
Old 02-23-2004, 04:34 PM
jharris jharris is offline
I have had the same hesitating problem. My mechanic/friend replaced my distrubtor and that fixed the problem. He went through several diagnostic checks and finally changed it out. It cost about $280 for the part.
I hope this helps you out.
Peace
Old 02-25-2004, 02:21 PM
MrCrazy's Avatar
MrCrazy MrCrazy is offline
dam you have 190,000 miles on your car, i have a 95 ex and i only have 90,000 on it (nearly double)
Old 06-06-2004, 05:47 PM
drock59 drock59 is offline
Re: 95 Civic hesitates REAL bad
ur over double???? 90+90=180
