Old 01-27-2006, 10:21 PM
PamzJoe PamzJoe is offline
Question about tire size.
I had a "tire guy" tell me today, that I could put 33's on my stock 17 inch wheels without any lift other than cranking the bars & then trimming the plastic piece that hangs infront of the fender. Is this true, or is he mistaken? I want to put a bigger more aggressive tread tire on my stock wheels. As always, money is an issue, (just had to fund a huge wedding for my daughter.) or I'd buy custom rims. (9 inch). Hopefully, those will come later. Let me know what my options are.
2005 Chevy Silverado Z71 ext. cab All factory suspention, tires & wheels.
Thanks.
Old 01-27-2006, 10:35 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: Question about tire size.
Thanks.
I am not sure about the tires, but nothing smaller than 17 inch rims will fit your truck due to brake clearance.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 01-27-2006, 11:59 PM
Im planning to stay with 17x9 inch rims whenever I do buy some. The factory rims are 17x7s.
Old 01-28-2006, 03:57 AM
Snowbrdr1122 Snowbrdr1122 is offline
Send a message via AIM to Snowbrdr1122
I can tell ya for sure its going to be a super tight fit... I tried to squeaze a 315 series tire under mine (got em off an H2 for free) and there was quiet a bit of rubbing... Now I plan to do a lift down the road, so I opted for 285's for now... All I did was crank my bars to level the truck, I was a lucky one, didnt have to replace the keys and my CV angels are acutaly still good
2005 Chevy Silverado 1500 Crew Cab Z-71
-Access Roll Top Tonneau
-Cranked T-bars
-285 BFG All Terrains
Next up, 10" lift, rims/tires, and exhaust
Old 01-28-2006, 11:35 AM
06Z71 06Z71 is offline
your tire guy is right 305 will fit if you trim about a 1"x1" piece of plastic and crank your bars
Cranked Bars
Silverstar headlight + 8 Light Mod
TrueFlow Intake + Airaid TBS
5% Window Tint + 30% On Front Windshield
Billet Grill + Bugshield + Ventvisors
And Still Spending
Old 01-29-2006, 08:22 PM
RyAmber RyAmber is offline
One problem with clearance is by going with a wider wheel, 9 inches instead of 7 the rubbing will increase. If you find a tire that will fit on a 8 inch wide rim you will be better off. Cranking torsion bars will help with clearance but an alignment is absolutely necessary afterwards and there are consequences to messing with them such as added stress on ball joints and what not plus recalibration of speedo will need to be done and depending on what gear you have in the rear you will sacrifice plenty of low end torque and off line power with tires that big
Old 01-29-2006, 10:10 PM
Thanks for the input. The more I think about it the more I'm leaning toward 285's. Do you think they'll be okay on the 9inch wheels? I've also heard something about a "leveling key". Can you shed some light?
Joe
Old 01-30-2006, 07:35 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
If you want to go any larger than a 305/70 then you might need the torsion keys to raise the front end. All it is is the same torsion key your truck has, but the hole is reindexed to add more lift when installed. If all you want is a 33" tire, I'd say go with 285's. Same height as a 33", just not as wide. With the 285/75's you shouldnt have to trim anything.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 01-30-2006, 09:50 AM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
You could even go with a 255/85/16. They are still 33" tall but not as wide as the 285's.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 01-30-2006, 10:02 PM
Did a lot of "Tire size research" today. I'm going with the leveling key, 285/70/17's on a 9inch wheel. Havent picked out the wheel style yet. Thanks for the input.
Joe
Old 02-08-2006, 09:39 PM
FiTxAg04's Avatar
FiTxAg04 FiTxAg04 is offline
What exactly do you have to trim to fit the 305s? How easy/hard is it to do?
I'm still deeply debating what to do myself. What exactly is the difference btw. the 285/75, 295/75 and the 305/70 (height difference/width difference)? Also, those 305s look really wide for the stock rims (very good look), but does this cause any problems as far as mounting and keeping the bead? I love how wide those are but I thought I'd have to get wider rims for a set of tires that wide.
Also, what size are the tires in your pic?
Thanks in advance for any info!
2004 Chevy z71
BF Goodrich T/A KO 285/75/16s. Flowmaster 40 Series exhaust. K&N intake. Stull billet grille. F-150 torsion bar index keys. 800w stereo system.
Old 02-09-2006, 07:51 AM
jeverett's Avatar
The tires in my pic are 285/75/16's They fit perfectly without any rubbing at all. All I did is crank the torsion bars a little.
To fit 305's all you would have to trim is the little plastic air dam right at the edge of the bumper closet to the tire. If you turn the bars some, you may not even have to do this. As far as the stock rims, they will work perfectly and to me, they look really good with that fat of a tire on them. They won't loose a bead at all, it actually helps them to retain the bead. If you get wider rims, you'll have all kinds of rubbing issues.
I've mounted tons of 305's on these trucks when I used to work at the tire store and only 1 time did I see any give trouble. They were Goodyear ATS.....those tires are crap!
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 02-09-2006, 02:44 PM
If anybody knows someone who's looking for some stock '05 Silverado wheels complete with a barely used set of P265/70R17 Bridgestone Dueler A/T's, cheap, give me a holler.
Joe
Old 02-09-2006, 08:33 PM
FiTxAg04's Avatar
jeverett....
Why is it that your 285 M/Ts look so much wider than the 285 A/Ts on Snowbrdr1122s truck? Is it just the camera angle? Are the tires on y'alls trucks both the same width? I really want that fat look and I want the A/Ts versus the M/Ts...if I can confirm that the width is the same, I'd rather go with the 285s over the 305s.
I really really hate this metric crap. Wish we could go back to the good ol' American system.
2004 Chevy z71
Old 02-10-2006, 07:37 AM
jeverett's Avatar
Originally Posted by FiTxAg04
jeverett....
The width is not the same, but the height is. A 305 is basically the exact same as a 33/12.5/16, a 285 is a little narrower.
Different tires will look differently when mounted. If you want the fattest look possible, get Goodyears...but I dont lke them. If you want some good A/T's, look at Bridgestone Dueler REVO's, or maybe some BFG A/T, or Cooper ATR's....
I had some of the old Coopers before they changed tread design and they rocked!!..let me find a pic for you with them.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
