Go Back   Automotive Forums Car Chat > Chrysler > Cirrus
Old 01-27-2006, 09:31 PM
jose_a_jimenez jose_a_jimenez is offline
Send a message via MSN to jose_a_jimenez Send a message via Yahoo to jose_a_jimenez
How to Check engine failure codes on 1996 Cirrus
How can I check the engine fault codes on my 1996 Cirrus? I try turning on and off the key but it did not work. And the Check Engine is on and I would like to know what fault is.
Old 01-31-2006, 03:47 PM
rsublime4life's Avatar
rsublime4life rsublime4life is offline
Re: How to Check engine failure codes on 1996 Cirrus
Go down to your loacl auto parts store and rent a diagnostic tool. they will charge you a refundable deposit. plug it in and find out what codes its throwing. This is the same things a mechanic charges you $100 to do and its free!
Old 02-04-2006, 05:04 PM
rolnaldo33's Avatar
rolnaldo33 rolnaldo33 is offline
Send a message via AIM to rolnaldo33
easy way to check, turn the key back and forth 5 times, don't crank the engine just turn it to the on posision. the service engine light will blink. count the number of times it blinks, it will blink x number of times, that will be the first diget...pause and then bliink x number of times again, thats the second diget. there will be a long pause between numbers. record the numbers and look up the diagnostic codes on the internet. they will tell you what each number means.
Old 02-20-2006, 05:50 AM
kplusten kplusten is offline
Where I live in VA, Auto Zone will hook up their diagnostic tester for free, and tell you what the code is. Their interest is to sell you the part you need if they have it, but it sure beats the $70 charge the dealer wanted for the same 5 minutes of work.
