Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 01-27-2006, 08:37 PM
goody54 goody54 is offline
p71 wont start
help!! i have a 2000 p71 i have gas pressure and still no start,,looked for fusable links that may have burnt but cant find any anywhere.tested fuel pump and all is working fine. i dont think im getting spark any ideas as to what could be causing this and what i can do to test or fix this would be very helpful. thanks
Old 01-28-2006, 07:00 PM
peppermrj's Avatar
peppermrj peppermrj is offline
Re: p71 wont start
First check for spark. Check your ignition fuses. What type of ignition system? Two coils or eight?
Old 01-28-2006, 07:02 PM
peppermrj's Avatar
Re: p71 wont start
Here is a link to an ignition system for a 98. It will give you an idea of the components involved if it is not your exact setup. Post back.
http://www1.autozone.com/servlet/UiB...3d80172632.jsp
Old 01-28-2006, 07:11 PM
Re: p71 wont start
i have the 8 coil pack system,,,,checked all fuses and all are ok....couldnt find all fusable links to see if that was it
Old 01-28-2006, 07:17 PM
peppermrj's Avatar
Re: p71 wont start
Do you have spark? Check several plugs.
Old 01-28-2006, 07:52 PM
p71 p71 is offline
Re: p71 wont start
i'm having that sort of issues 2. i had 3 bad coil packs. still have a rough running motor. checked EVERYTHING! i have a 2000 cvic p71 with 195k. peppermrj; what is the truth on the learning curve of the pcm? it has been hard reset. how many miles for it to learn?
Old 01-28-2006, 07:57 PM
p71 p71 is offline
Re: p71 wont start
i also have a 2000 p71 vic. had 3 bad coil packs. still not running smooth. checked everything, replaced iac/harness/filters/pump/3 coils/plugs. have p0453 code-evap ecs press sensor high?? any help?? can't figure out where it is.
Old 01-28-2006, 07:58 PM
peppermrj's Avatar
Post Re: p71 wont start
Wish I knew for sure. It does take some time tho. There are several cylces it must go thru. Have you cleaned/checked your EGR?
Old 01-28-2006, 08:06 PM
p71 p71 is offline
Re: p71 wont start
not yet. did pull the egr valve. it was ok. used lots of cleaner on tb, etc. has a backfire when floored while driving. only when kicked down/ high rpm. idles rough, but consistent. no stalling. i'm worried about injectors. a pain to check. last resort.
Old 01-29-2006, 12:47 PM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Re: p71 wont start
Have you pulled the error codes off the computer? Try running a can of SeaFoam throught the engine/gas tank it's worth the $6. Can get it at NAPA/Carquest. www.seafoamsales.com
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
Old 01-29-2006, 03:15 PM
p71 p71 is offline
Re: p71 wont start
the only code left is p0453. don't know what or where it is. cleaned injector/fuel system well, and changed all filters & pump. coils/plugs too.iac is new. even gave it a bath and a hug. still no improvement.
Old 02-07-2006, 12:45 PM
p71 p71 is offline
Arrow Re: p71 wont start
update: after a week of driving(200+ miles) still not much better. a little maybe. does not backfire now. i'm still suspecting weak coils. perhaps a thermal breakdown? still only the above fault code. still don't know what it is. even tried a different set of mufflers. no difference. my cats are hollow. now runs fair under harsh acceleration, but poor idle. ideas??
Old 02-07-2006, 01:56 PM
mtmaurer8ooo mtmaurer8ooo is offline
Re: p71 wont start
FYI - I don't know if you know p71, but your P0453 code says Fuel Tank Pressure Signal circuit Input above maximum. I don't know exactly what that translates too but it sounds to me like you may have some evap system problems. Check the evap canister vent solenoid(purge valve)...it may be malfunctioning. Also, I don't know too much about these crown vics but its my understanding that they do have some issues w/ intake gaskets, so she may be sucking air also. Just a couple things to check out. Let us know what you find. M
Old 02-07-2006, 02:14 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
Re: p71 wont start
have u tryed a mass airflow clean ans also the seafoam is an awsome product ive used it in my cars plus friends cars its awsome heres some links
http://www.lincolnsonline.com/tech/00151.html
http://www.lincolnsonline.com/tech/00059.html
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 02-07-2006, 03:15 PM
p71 p71 is offline
Re: p71 wont start
HERE'S THE "ACTRON" DEFINITION OF THE CODE p0453:
"EVAP EMISSION CONTROL SYSTEM PRES SENSOR HIGH"
between that and yours, it seems to point to the sensor's reading being too high. ...or is that "ford" for a high supply voltage to the sensor...or is that a logic high when the pcm expects a logic low/voltage below x volts????
i did fix the connector on the module under the tank. it had been ripped off. had some other code with that; but after i fixed it, code went away. this one was there all along.
any tips for the purge valve testing/cleaning? i'm not familiar with doing that. i am gathering that it is the module under the trunk.
i have not thoroughly cleaned the maf yet, but will today. can't find any air leaks or vacum issues.
why don't fords come with ctrl/alt/del??
