Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-27-2006, 05:02 PM
JMM8586 JMM8586 is offline
1990 Mitsubishi Eclipse....Sputters under load
I have a 1990 Mitsu Eclipse 1.8 non turbo...Under load the engine sputters after 4,000 Rpm....there is no CEL. If I roll the accelerator on the motor will go up to 6,000. Only after 3/4 of acceleration the engine sputters. Any help would be appeciated..Thanx
Old 01-27-2006, 05:03 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: 1990 Mitsubishi Eclipse....Sputters under load
Check the plugs and wires. Replace and regap if necessary.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 01-27-2006, 05:25 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 01-27-2006, 07:17 PM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Welcome to the forums JMM8586! Please post in the correct sub-forums.
The daily driver. The weekend cruiser. The lazy shop hog.
Old 01-27-2006, 10:06 PM
ok well ill do that tommorow. I just picked up the car for $250. It needs a little work. But everything else seems to work fine. The motor runs strong otherwise. Ill tune her up tommorow, along with compound buffing the paint to see if i can make it shine again...Thanx
Old 01-28-2006, 06:43 AM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
endless,i love the look of those rims on your srt-4.good choice,as for the sputtering ther is a few things to check like what they said about the plugs also try to clean out the fuel injectors im sure that will help,jiffylube has a good servise for the injectors try that
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
