Old 01-27-2006, 03:45 PM
nineball481's Avatar
nineball481 nineball481 is offline
Angry Tranny is slipping
The fluid was changed at 50Kmiles, I'm now at 64kmiles. I checked the fluid, and it still has plenty. Yet My tranny has started to slip. Mainly while at speed. I willl try to accelerate from 55-60 to 65-70. I can feel and hear the tranny slip from 1700rmp to 2300rpm.
Any suggestions?
It will slip at lower speeds as well (20-30range). I still am under warranty from the dealer. I know if I take it in, the problem will be miraculously fixed, until I leave, after paying a troubleshooting fee.
Essentials:
2000 1500 4.8L 4L60e 64Kmiles, fluid/filter changed 14kmiles ago.
Thanks,
Jake
  • K&N cold air intake
  • Functional cowl induction hood
  • short tube headers
  • Hypertech PP III
  • 20" Helo Renegades wrapped w/ Toyo Proxes S/T
  • Escalade instrument cluster
  • TYC tail lights and corner lights
  • Wet Okole seat covers
Some people see things as they are and say "Why?". I dream of things that never were and say "Why not.""
-George Bernard Shaw
"Mind over matter: If she doesn't mind, It doesn't matter"
-Nineball
Old 01-27-2006, 04:54 PM
tykrz's Avatar
tykrz tykrz is offline
Re: Tranny is slipping
Put it in drive or reverse, foot on the brakes with gas pedal on the floor till the transmission frys itself. Shouldn't take much longer than 5-10 minutes tops. Wont hurt the engine as it will only rev to about 1500 to 2000 rpm. Then call the dealer to fix it.
Old 01-27-2006, 08:56 PM
troy1 troy1 is offline
AF -Advisor
does it slip in all the gears or just 3rd or 4th? Who changed the filter and is the fuild level good?
Old 01-27-2006, 09:05 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Have you checked that your MAF sensor is not fouled with oil from your K&N? I read in another post on this board (by GMMerlin, i think) that a gooey MAF can cause the tranny to slip.
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 01-28-2006, 12:24 PM
I don't wanna fry the tranny, my luck they would be able to pin the damage on me!
I'm not 100%sure if it slips in all gears. Pretty sure it slips from 2-3 and definetely 3-4.
I changed the fluid and filter myself. The operation was rather straight forward (drain, unbolt, pull filter, install new filter (with o-ring), rebolt and fill). The level, as far as I can tell is good, fluid is still looks good.
Thanks for the help everyone.
Jake
  • Hypertech PP III
-Nineball
Old 01-29-2006, 01:44 AM
tykrz's Avatar
Unfortunately when a tranny starts to slip there is no quick miracle fix short of an overhaul involving new clutch packs, bands and internal seals. Usually what starts the damage is heat causing the seals to go brittle. Once it starts to slip you've already damaged the friction material on the clutch packs of which there isn't much to start with. If you dont have a good heavy duty auxilliary transmission oil cooler, get one installed as the cooler the oil the longer it will last. Usually GM transmissions are quite good but ensure that the underlying problem which caused it to fail is fixed if you do overhaul it. Frying would only be a last resort if your dealer tried to pawn it off as normal.
Old 01-29-2006, 10:28 AM
jveik jveik is offline
lol yeah just dont do those huge burnouts in which you upshift all the way to 3rd gear sittin still and the tranny would last a while. unless its an old beater with a th400, their beefy mother truckers
Old 01-30-2006, 07:25 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
I did a nice burnout this weekend only through 2 gears though.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 02-13-2006, 08:58 PM
pwhitaker pwhitaker is offline
does anyone have a diagram on how to overhaul a chevy automatic tranny...85...4wd...thanks in advance
Old 02-13-2006, 09:16 PM
2000CAYukon 2000CAYukon is offline
A diagram? How about a video?
http://www.technicalvideos.com/video...smission.phtml
Or a book?
http://www.technicalvideos.com/books/transmission.phtml
//2000CAYukon
Old 02-16-2006, 01:29 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
I would do a complete Transmission Flush, before you make the expense of doing an overhaul.. My tranny will start to slip when it is time to service it.. After a tranny flush.. presto.. all better. In fact I am about due for one soon
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
